Tom's Hardware > Forum > CPU & Components > Other Components > Antec 1080 430watt case fan problems
Forum CPU & Components : Other Components - Antec 1080 430watt case fan problems
Hello,
As of the past day, whenever I turn on my antec 1080 case w/ 430 watt truepowerPSU the chassis, PSU, and system fans do not turn on. The cpu fan works fine though. Could anybody tell me whats wrong here?
BTW My system specs. are:
2800+ Athlon w/512k cache
80gigabyte SATA Seagate barracuda
48x Pioneer CD/DVD player
52x Liteon Cd burner
ASUS A7N8X deluxe
Radeon 9700 pro
2x 256 DDR 2700
Sponsored Links
I've got the exact same case.
Check the power connections to the fans (make sure they arent disconnected or upside down or loose or something). Also, make sure that they are not disabled in the BIOS.
Hope it helps!
Reply to Vonkwink
Thats strange that the PSU and chassy fans dont work.
If it were just the chassy ones one could theorise that the mobo is damages somehow.
Does the system still boot ok and run properly?
I would hook the casefans up to molex connectors to make sure they still work ok.
<b>When life hands you lemons, ask for a bottle of tequila and salt</b>
<A HREF="http://members.iinet.net.au/~lhgpoobaa/images" target="_new">My Images!</A>
Reply to lhgpoobaa
- 0 +
How did you connect the fans? With special fan connectors of the CPU, with the motherboard or with the 4-pin molex connectors?
My dual-PSU PC is so powerfull that the neighbourhood dims when I turn it on :eek:
Reply to svol
No the system boots up just fine but the chassis and PSU fans don't work. I'm sure everything is connected fine. I'll try using 4-pin molex connectors. I still can't figure out why my PSU fan does not work. Should I return my case?
Reply to airjesus
There are 1210 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 16:28 bilbat won the Motherboards badge
  • 01:00 jayhsyn won the Freshman badge
  • 01:00 nesta13 won the Freshman badge
  • 01:00 petar won the Freshman badge
  • 01:00 sinsear won the Freshman badge
  • 01:00 UnawareAtol won the Uniformed badge
  • 01:00 buryaku won the Uniformed badge
  • 01:00 Redras0324 won the Uniformed badge
  • 01:00 dvdmania won the Uniformed badge
  • 01:00 ugotomega won the Uniformed badge
