Registry Problems!!!!!
Hello!
My Windows XP Professional computer always gives this STOP error:
The registry could not load the hive System32\SOFTWARE It is corrupt, absent, or not writiable.
Or something like that.
I have reinstalled and reformated my computer over and over and this keeps happening. I have also installed the Q317277_WXP_SP1_x86_ENU.exe hotfix with no result.
How can I fix this?!? I don't want to go back to Win 2000 or Me but I can't reinstall my computer every day!
Thanks in Advance!
9 answers Last reply
More about registry problems
  1. I found this MS article: <A HREF="http://support.microsoft.com/default.aspx?scid=kb;EN-US;q156640" target="_new">Q156640</A>
    I'm gonna point out these portions:
    <font color=green>The registry files may have been corrupted because of hard disk corruption or some other hardware problem.</font color=green>
    <font color=red>If the STOP error message was caused by a hardware problem (for example, bad sectors on the hard drive), the drive may require a low-level format, repartition, reformat, and a restore of the entire system from a tape backup to clear up the problem. Although this would be the most drastic case, if the STOP error message was caused by a physically bad sector, the sector must be relocated with a low-level format.</font color=red>
    So, hopefully this'll be the last clean install you'd have to do. Before you do this, get the utility from your hard drive manufacturer to do a low level format (LLF). That should probably take all night, depending on the size of your hard drive. Then, do a clean install. When it asks what filesystem you want to use, don't do a quick format, but a standard one. You can take it from there.
    Good luck...
    Bryan
    <font color=red><A HREF="http://www.btvillarin.com" target="_new">btvillarin.com</A> - My Windows XP-based Website</font color=red>
  2. You might want to check your memory:
    <A HREF="http://198.95.255.5/NonCGI/Forum13/HTML/000052.html" target="_new">Adrian Wong Post</A>
    <A HREF="http://www.pctnt.net/hive.htm" target="_new">Cannot Start Windows XP if the System or Software Hive Is Missing or Damaged</A>
    Toejam31
    <font color=red>My Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=6847" target="_new"><font color=green>Toejam31's Tantalizing Tantric Toy</font color=green></A>
    <font color=red>Second Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=15942" target="_new"><font color=green>Toey's Dynamite DDR Duron</font color=green></A>
    __________________________________________________________
    <font color=purple>"Some push the envelope. Some just lick it. And some can't find the flap."</font color=purple>
  3. Thanks for replying.
    No, I have used ChkDsk and there are no bad sectors on the HDD. I have read that the problem may be caused by the computer turning off too fast, before the registry is closed, but I installed the hotfix for that and it does not help.
  4. I think you should do what ToeJam recommends first, because I doubt it's because the computer's shutting down too fast. Another reason it would be good to check your memory, especially if you got some generic stuff.
    (What's up Toey! Haven't talked to ya in awhile... :smile: )
  5. ditto on the ToeJam idea. Go into the BIOS and underclock your RAM (set the CAS level higher, set the frequency lower, etc.) and see if you still get the problem.
    <i>It's always the one thing you never suspected.</i>
  6. I haven't seen many systems where enabling the write-cache for the hard drives caused this kind of problem. It's possible for a fast shutdown to cause data corruption, but it doesn't happen often ... and it is usually intermittent. And if you've installed the hotfix, then the problem lies elsewhere.
    Everything seems to point toward your memory being flaky. Have you tested it yet? <A HREF="http://www.teresaudio.com/memtest86/" target="_new">MemTest86</A>
    Toejam31
  7. What's happening, bt? It's all good, I hope?
    Toey
  8. Definitely all good. :smile:
    Bryan
  9. Hello!
    I discovered what the problem was: the memory. (Thanks ToeJam!)
    I downloaded DocMemory from www.simmtester.com and tested the memory. Errors.
    I purchased new memory. (As I live on a small island, it's expensive: $69 for 128 PC-133)
    No problems at all.
    Thanks!
Computers Registry Windows XP
