Closed Solved
Wifi authentication problem
I have and and android tablet I just bought and I can't connect to the internet with my Belkin N300 Router all my computers and smartphone work very good to this router and the phone works with wifi here also. I can't get this tablet to connect to the server I have put in all the ssid and the name of the server. When I try to connect it says connecting, then autherizing and then it does a loop and does not ever change,keeps on doing it. In the little shell that is to change color when connected there is a very small lock showing and I am not sure just what todo about this ...I was hoping that you have answers for me , thanks Ann
3 answers Last reply Best Answer
More about wifi authentication problem
  1. Best answer
    Did you also put in the security passcode for your wireless?
  2. Best answer selected by Bunkieann.
    yes I did
Connectivity Connection Authentication Wireless Networking
