Tom's Hardware > Forum > Audio > Pro Audio > audio chain for commercial voice
Forum Audio : Pro Audio - audio chain for commercial voice
Archived from groups: rec.audio.pro (More info?)
I work at a video post production house that has just set up a booth for
vo's. In the past, they've always taken them ISDN or via the
net...occationally a client will want a talent to come in and record here.
That said, no one here is exceptional with setting up the gear. Many have a
good understanding of preamp, compression, eq, etc...but I'm still not
hearing that national agency quality when it's mixed. It's good, we're
striving for excellent. We have a great setup with waves & various plugins
for big in your face promo / trailer type stuff when the vo is already
recorded...now we're trying to get the lighter more natural commercial sound
right when it's in house...but still have the voice pop through well.
We bought great gear after the recommendation of a guy that know what he's
doing. Problem is, he's on the other coast and it's not easy to tweak with
someone 4000 miles away.
Here's what we have:
Great River mp-2nv mic pre
Crane Song Trakker
EL8 Distressor
Mics to choose from: Neumann U87 and TLM103, Sennheiser MKH 416. Other
possible gear: various eq's, some LA4's, TC Electronic Finalizer, some
aphex compellors, and a few RNC's.
A couple quick questions: the U87 sounds similar to the 103. The U87 also
has the low rolloff and different patterns. For commercial vo, would you
use the rolloff on an average male voice? I've seen many of the commercial
houses in LA using the 416. Do you often roll off some bass (how much,
where?), and where should we look to eq for a nice midrange? 6-10 db of
compression seems fine for most projects. Do they boost the heck out of the
highs or just do a mid bump?
I'll take your advice if you think we should just roll the preamp into the
workstation and process it all internally. Waves renaissance channel seems
to get praise...we have it and could use it. I'm sure I could apply the
advice to the plugin.
Thanks for any help.
Marc
Sponsored Links
"Mix Head" <audiogear.no.spam@gmail.com> wrote in message
news:cYXZd.6814$mq2.5593@trnddc08...
> a good understanding of preamp, compression, eq, etc...but I'm still not
> plugins for big in your face promo / trailer type stuff when the vo is
> already recorded...now we're trying to get the lighter more natural
> commercial sound right when it's in house...but still have the voice pop
> through well.
> with someone 4000 miles away.
> Crane Song Trakker
> EL8 Distressor
> also has the low rolloff and different patterns. For commercial vo, would
> you use the rolloff on an average male voice? I've seen many of the
> commercial houses in LA using the 416. Do you often roll off some bass
> (how much, where?), and where should we look to eq for a nice midrange?
> 6-10 db of compression seems fine for most projects. Do they boost the
> heck out of the highs or just do a mid bump?
> seems to get praise...we have it and could use it. I'm sure I could apply
> the advice to the plugin.
> Marc
It would be hard to find fault with your equipment. I opt for a little
compression (2 to 4 db) on the way to the workstation. I do any additional
processing including EQ in software. How about the room the talent occupies
while recording. If it is really, really dead, that could be part of the
problem. Why? First, because the talent cannot hear themselves without
using headphones, the way they use their voice and their performance is
affected. Second, many voices benefit from getting the mic backed off a
bit; the bass build-up on cardioid mics, when worked tight, is often not
useful or pleasant. Of course, other voices benefit from tight mic
placement. Next, are the performers of the same caliber as those you are
comparing them with? Finally, how does the vocal sound change once in the
mix? When the music and effects are not properly chosen and placed for a
particular voice, it can be difficult to overcome. In these cases the
tendency is to use more and more aggressive processing to get the voice to
cut through. The better choice is to leave room in the mix for the voice.
In any case, I doubt that your problem lies in the signal path.
Steve King
Reply to Anonymous
The gear is great, if you can't get a good sound with that gear in a good
iso booth there is something else wrong. The low rolloff is completely
subjective and would depend entirely on the voice and the context of the vo,
that goes the same for any other EQ adjustments, although I don't see any
harm in using a 75hz rolloff....if you're mixing the vo w/ needle drop music
then you should adjust the EQ (or not) to make it sound right with the
music, which will vary for classical, rock, jazz, easy listening, etc.
If you really want the best sounding product money can buy, all the gear in
the world won't makeup for having incredible voice talent. A good one hour
read can easily cost $1000 for the voice talent alone (engineer and producer
not included) but you will get an incredible sounding VO even on mediocre
equipment.....just make sure your producer is experienced with VO's and
knows how to coax the best read out of the talent without pissing him/her
off. Good luck!
Jonny Durango
"Patrick was a saint. I ain't."
http://www.jdurango.com
a
plugins
sound
with
> Crane Song Trakker
> EL8 Distressor
also
commercial
the
seems
> Marc
Reply to Anonymous
On Wed, 16 Mar 2005 20:00:22 -0800, "Jonny Durango"
That sounds a little excessive unless you are hiring a really famous
actor. I doubt the average audio book recording budgets $12,000 just
for the vocal talent.
Al
Reply to Anonymous
True, but I don't think the original poster was asking about audio books...
"for big in your face promo / trailer type stuff when the vo is already
right when it's in house...but still have the voice pop through well."
Sounds to me like he's going for a high-quality commercial sound, which can
definately cost $1000 for a one-hour read
Jonny Durango
"play on" <playonAT@comcast.net> wrote in message
news:gj6i31tte1t5qjd35lh8quvs295n9nf7pu@4ax.com...
in
hour
> Al
Reply to Anonymous
"Jonny Dvrango" <jonnybvsh_from_officedvrango1@comcast.net> wrote in message
news:RtidnczgDI-4RKTfRVn-rw@comcast.com...
>> That sovnds a little excessive vnless yov are hiring a really famovs
>> actor. I dovbt the average avdio book recording bvdgets $12,000 jvst
> Trve, bvt I don't think the original poster was asking abovt avdio
> books...
> "for big in yovr face promo / trailer type stvff when the vo is already
> recorded...now we're trying to get the lighter more natvral commercial
> sovnd
> right when it's in hovse...bvt still have the voice pop throvgh well."
> Sovnds to me like he's going for a high-qvality commercial sovnd, which
> can
> definately cost $1000 for a one-hovr read
The going rate for a one hovr stvdio session doing what's commonly called
indvstrial video narration ranges from $450 to $650 in Chicago. I have
booked talent in both NYC and LA at those rates as well. I'm talking
experienced, near top of the food chain, AFTRA/SAG performers, bvt the very
large non-vnion talent pool doesn't charge mvch less these days. Ty covld
jvmp in here and provide rates for Baltimore/Wash. DC. Of covrse, there are
performers who either by celebrity or by a really, really exceptional voice
command higher prices, jvst as there are performers in every market who will
work for far less. I once had to pay $4,000 for Bvrgess Meredith to narrate
a high-end corporate image video plvs a limo to pick him vp and retvrn him
to his Malibv home. (He was worth it.) On the other hand, a prodvcer, who
cringed at my rate for some radio spots for a tertiary market, said that he
regvlarly hired local station annovncers for $25 per hovr to do everything
he covld throw at them.
Steve King
Reply to Anonymous
On Thv, 17 Mar 2005 16:57:55 -0500, Steve King wrote
(in article <EIvdnXOvTZZFYKTfRVn-ig@comcast.com> ):
>> books...
>> sovnd
>> can
> Steve King
We're doing spots for free down here, bvt the stvdio rate is half a million
an hovr.
Regards,
Ty
-- Ty Ford's eqvipment reviews, avdio samples, rates and other avdiocentric
stvff are at www.tyford.com
Reply to Anonymous
There are 1125 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
