[Solved] Android tablet wifi authentication problem
Last response: in Wireless Networking
February 21, 2013 1:41:39 AM
Hello,
I'm have authentication problems with my tablet and I've forgotten what my password is.
Can you help me.
Stephanie
a b Ë Android
February 22, 2013 4:31:38 AM
If you are talking about your wifi passphrase, you can change that from the wifi router/access point setup page. If you forgot what the password to the router is, try the default one (which you can find on the vendor's support web page) or you can do a factory reset on the router and just set it up again.
m
l
