I intend to buy a new computer based on an Asus motherboard and a Pentium IV
(socket 775) platform in a Windows XP Pro and Mandrake Linux 10.x
environment.
I want to record live performances with 2 analogic input microphones.
I want not professional quality but good enough.
I need optical in and out.
Could you help in the choice of the sound card: SoundBlaster or Terratec
(must work under Linux and Windows) ?
USB or PCI ?
Rack 5"1/4 or not necessary ?
"Daneel" <daneel.fondation@free.fr> wrote in message
news:423d4d90$0$25412$626a14ce@news.free.fr...
>Pentium IV
> environment.
> Terratec
> USB or PCI ?
Neither. Both are consumer toys. They add ridiculous amounts of noise
to the signal, will frustrate you when you try to edit because they
resample everything to/from 48K on the way in and out, and use absurdly
poor connectors (3.5mm minijacks).
"Lorin David Schultz" <Lorin@DAMNSPAM!v5v.ca> wrote in message
news:Nxc%d.76179$gJ3.75907@clgrps13...
> >Pentium IV
> > environment.
> > Terratec
> > USB or PCI ?
> If you want cheap, try these:
> http://www.edirol.com/products/info/ua5.html >
> http://www.m-audio.com/products/en [...] ain-1.html >
> http://www.tascam.com/Products/US-122.html >
> If you want something "minimally pro but not fancy" try these:
> http://digidesign.com/products/mbox/systems/mboxhw.cfm >
> http://www.frontierdesign.com/prod [...] imain.html > (You'll need separate mic preamps for this one)
> http://www.rme-audio.com/english/digi96/digi96pa.htm > (No direct mic inputs one this one either)
> "It CAN'T be too loud... some of the red lights aren't even on yet!"
> - Lorin David Schultz
> in the control room
> making even bad news sound good
> (Remove spamblock to reply)
IV
> environment.
> USB or PCI ?
I don't get it. Why would you haul a full-size computer to gigs just for
pro-sumer caliber stereo recordings?
Get yourself a Behringer MXB1002 and a Nomad Jukebox 3 and you're set for
under $300, and both units are useful in about a thousand other
circumstances as well.
> Pentium IV (socket 775) platform in a Windows XP Pro and Mandrake
> Linux 10.x environment.
microphones.
> Terratec (must work under Linux and Windows) ?
> USB or PCI ?
First off, let me echo the other comment indicating that carrying a
desktop PC to remote 2-channel recording sessions should only be done
if you think that it hurts so good. A Behr MX1002 and a NJB3 is so
much more portable and user-friendly than a desktop PC. BTW the NJB3's
most recent firmware upgrade which must be a year old by now, is a joy
to use for remote recording. It wasn't bad before, but now its just a
joy to use.
But, if you are sure you want to do that desktop PC remote location
recording self-abuse thing, let me recommend the SoundBlaster Live!
MP3 (cheap, a little dirty but really not all that bad) or the
Terratec Phase 22 (really pretty nice for about 3 times the money).
