Connecting a wireless router to another wireless router
Hi guys, I'm trying to add another wireless router to my network. It's a home network using a Charter cable modem/wireless router in the main house. To connect a second building to the router I have used a CAT-6 cable to connect to the modem/router combo, I need to do this because the second building has a metal roof and doesn't allow wireless connection to the cable modem. I want to be able to use wireless in the second building.
My question is, the CAT-6 cable coming into the second building from the cable modem/router is coming from a LAN port. Would I connect that cable into the WAN port of the second wireless router or into a LAN port?
Cable modem LAN ---->second building----> Second Wireless router
Any help would be appreciated. Thanks.
1 answer Last reply
More about connecting wireless router wireless router
    Couldnt you just try both ports when you're wiring it up to see which one works? Plugging one router into another will work fine as long as its plugged in correctly.
Configuration Wireless Router Connection Modem Cable Wireless Networking
