"Figaro" <mozartman2000@aol.com> wrote in message
news:1111432969.265334.296370@f14g2000cwb.googlegroups.com...
> Is there such a thing? Please advise.
Even if you could find such a beast, it probably wouldn't sound very good,
and to top that, you are GOING to have wires of one kind or another. If you
found a set of speakers in which the signal got from the receiver to the
speakers without wires, you still need power to amplify it, which means each
of the 5 speakers will need to plug into the wall to power the built-in
amplificatioon you will need.
Your best bet is to get a good set of 5.1 speakers, and hide the wiring.
Maybe run it through the walls, the basement, the attic, under carpets, etc.
Kendall
> If not, what are the alternatives? I don't like wires.
> Thx
