Archived from groups: rec.audio.pro (
More info?)
On Wed, 23 Mar 2005 08:23:13 -0800, Jay Kadis <jay@ccrma.stanford.edu>
wrote:
>In article <nbo141t4b02pf6aslqrbgsi6jn2lhvnere@4ax.com>,
> Chris Hornbeck <chrishornbeckremovethis@att.net> wrote:
>> Several audio related devices exhibit zero-crossing
>> "flat-spots", regions in their transfer curves near
>> zero crossing where the Y axis output is transitionally
>> flat. Poorly designed push-pull amplifiers exhibit
>> "crossover distortion", magnetic storage has poorly
>> characterized related effects, etc.
>> Question: is this electronic "backlash", to use an old
>> mechanist's term, conceptually related (at all?) to the
>> well understood issue of quantizing distortion/ error?
>> And, if so, could classical dither be considered to be
>> a possible remedy?
The analogy between tape bias and dither has been mentioned here
before. What these all appear to have in common is the system has one
or more "dead bands" and adding the appropriate "non-signal" to the
signal reduces or eliminates this dead band(s) in the output.
Magnetics and push-pull amplifiers have one fairly large dead band,
and digital systems have lots of tiny dead bands, one between every
two consecutive digital values.
>In terms of analog magnetic recording, AC bias does in fact accomplish something
>similar to dither. I don't think it is conceptually the same, though, since the
>amplitude of the bias signal exceeds the signal amplitude.
It depends on how you define "conceptually" (sorry, I always feel a
like President Clinton saying that...) - at the basic level of "an
added signal fixes a dead band" they are the same.
>In A/D dither, the
>"bias" signal is a fraction of the LSB in amplitude.
It's actually a LARGE fraction, roughly equal to one LSB, though
it's still quite small relative to the peak signal, whereas (as you
say) tape bias is quite large relative to the signal.
Digital systems have very small "dead spots" whereas ferromagnetics
have one very large "dead spot." The magnetic dead spot is unique in
that it MOVES in the direction you want to magnetize something (the
hysteresis), so the bias (or dither) signal needs an even higher
amplitude to compensate for it. Basically, the bias/dither signal is
made large enough to get rid of the dead band.
I've not heard of a mechanical system that uses vibration
(coparable to dither or AC tape bias) to get rid of a deadband, but
I've seen gears for variable capacitors (used for tuning radios, where
backlash is very undesirable) where the larger gear is actually two
gears side-by-side with a spring pushing the teeth on to both sides of
each pinion tooth (hope I described that adequately). This is
analogous to a "correctly biased" class AB push-pull amplifier
circuit.
>-Jay
http://mindspring.com/~benbradley
