Archived from groups: alt.cellular.sprintpcs (More info?)
anyone have problems getting their TM msgs on Wednesday march 16?
Do SPCS and VM use same text message system?
Gor international long distance I have use OneSuite on both
SPCS and VM
Incredibly low long distance phone rates, as low as USA-Canada 1.9CPM!
Works as prepaid phone card. PIN not needed for calls from home or cell
phone. Compare the rates at
https://www.onesuite.com/ No monthly fee or
minimum. Use promotion code "034720367" for some FREE time.
Do you genuinely have this problem, or are you just spamming the
newsgroup, as indicated below?
> Gor international long distance I have use SpammitySpamSpam on both
> SPCS and VM
> https://www.spammityspamspam.com/ No monthly fee or
> minimum. Use promotion code "spammityspamspam" for some FREE time.
E-mail fudged to thwart spammers.
Transpose the c's and a's in my e-mail address to reply.
> SPCS and VM
using the code YG9uWQLG you could get 60 minutes when you first top up your virgin mobile phone this realllyyyyyyyyy works!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.
Yes! I seem to have started having problems on 3/17/09 and it has continued through today. VM to VM doesn't seem to be a problem. Plus I received a TM that was not meant for me and the sender had no idea how I received it. They had no record of sending it to my phone. Called VM today and they were NO help at all. In fact, I could not get them to understand what I was asking and I was very clear. I ended up hanging up in the middle of a completely misguided answer (and I'm usually polite to help desks, etc.) Very frustrating.
