Hi,
acquired a sound level meter that had a broken sound level meter. The
moving coil meter (which was 50uA full scale) was broken. The only meter
I could get that was physically the same size was a 100uA unit. Clearly
this was going to under-read, so with no better alternative, I placed
the meter in an environment where the meter was half scale (i.e. in the
middle) and adjusted the calibration control until it was full scale,
since my replacement meter was only half the sensitivity.
I doubt there is, but are there any simple calibration techniques I
could use to get the meter about right? I've no idea if the calibration
control has ever been fiddled with, and although my meter needs double
the current, that does not mean it will actually read twice as much as
the original, as they will have different internal resistances.
I basically acquired this to make comparative measurements, but it would
be nice if it was right - or nearly so.
I did a couple of quick checks.
TV on in a room at a comfortable level - 50 to 60 dBA.
I've not had a hearing test, but I'm only 42, so I doubt it will be too
bad.
Does that sound way out, or semi-reasonable? Any better ideas how I can
get it calibrated, without the expense of buying calibration equipment?
In article <424435b9@212.67.96.135>, Dave <nospam@nowhere.com> wrote:
>Hi,
What kind of meter is this?
With some meters, the coil resistance may be important, and in most
cases the meter dynamics will be important unless you're operating in
SLOW mode.
What is it? Is it an old Gen Rad or something for which parts are
readily available?
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
>>Hi,
> SLOW mode.
> readily available?
> --scott
It's a Castle Associates CS. 15C. The front panel is marked Scarborough
UK. It looks like them (or someone very similar) is in existance:
There can't be too many companies with the name Castle, specilising in
sound meters in Scarborough.
I don't know what the resistance of the 100uA moving coil was, as in an
attempt to repair it, the coil got damaged.
There is slow/fast switch, an OFF/BAT CHECK/ON switch, a rotary switch
with positions of 40, 50, 60, 60, 80 and 90. The scale shows -5 dB to
+10 dB. It takes a PP3 9V battery.
I could photograph it an put it on a web site if it will be any help.
The electronics in this thing is really simple. It must be 20 years old.
Not an IC in site.
The battery check does not work properly now, as all readings are about
50% lower than they should be. But I could easily change a resitor to
fix that. (I am an electroincs engineer).
I don't fancy paying for a new moving coil meter. If it needs me buying
another moving coil, I'll probably just stick with it for qualitative
purposes. I was trying to find out what parts of my computer make the
most noise, as there are two external disks, and so having something
that is at least qualitative is useful. But quantitative, even if not
particulary accurate, would be nice.
I guess finding the resistance of the original meter would be useful. It
will almost certainly be higher than the 100uA unit I fitted.
I guess there is no harm in dropping Castle Group an email.
>>Hi,
Give them a call and ask if they have parts.
To calibrate the thing, you either need a sound source with a known level,
or a known-accurate meter. You can build a source with a known level that
is entirely mechanical; it used to be common to modify model airplane engines
to produce a calibrated sound pressure in a chamber. Or, you can buy the
Radio Shack sound level meter (in the US anyway) for twenty bucks and
assume it's accurately calibrated. Or borrow a meter from someone...
--scott
In article <424443d3@212.67.96.135> nospam@nowhere.com writes:
> purposes.
For less than a replacement meter, you can buy a Radio Shack sound
level meter which, unless the one you have goes down to really low
levels) will be find for any audio survey work. I think they've
stopped selling the analog meters. Look for one on eBay. Should be $20
or so.
This is really difficult to measure. I know it's damn annoying, but
it's really not all that loud. You'll need a very silent room and a
meter that's more sensitive than the Radio Shack. Does yours have a
scale that goes down to 20 dB SPL? You also need to know the frequency
spectrum of the noise in order to get a sense of what kind of "fixing"
you're doing - assuming you're trying to improve your noise situation.
You might do better with a microphone, a nice quiet preamp, and a
computer equipped with a spectrum analyzer program.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
In article <42444b8a@212.67.96.135> nospam@nowhere.com writes:
> Here's a picture
That looks like a really cheezy meter (the thing with the pointer, not
necessarily the instrument) but unfortunately the sources for such
have pretty much dried up unless you're an OEM. But looking at the
range switch, this meter won't be of any use to you for measuring
computer noise. It's not sensitive enough.
>>Here's a picture
Sorry, I don't know what you mean by "cherry". The moving coil meter is
the same size (within a mm or so) of the original one. I removed the dBA
scale from the original moving coil meter, but had to take a file to the
scale a bit, as some parts of the scale were fouling on the new moving
coil movement.
Well, my computer is showing 53 dBA with the instrument on the desk, and
the computer to the side on it. In other words, the meter can not be
used on its most sensitive range, as it otherwise hits full scale.
The computer is a Sun Ultra 80 workstation, with 10,000 rpm disks, and
two external 10,000 rpm disks. I think the machine is rated for use to
about 50 deg C, and 10,000' above sea level, so there is a lot of
cooling air. It has 4 CPUs and 4GB RAM - not a typical home PC.
>>purposes.
> or so.
I got the 100uA meter free. So far, the sound level meter and repair it
has cost me a grand total of zero.
It's showing 53dBA on the scale with the meter a couple of metres from
the computer. That is too much for the low end of the scale.
Strange you say that. I found an electret mic and was going to put it
together with an op-amp and build my own sound meter, but I threw it in
the bin when I got this meter. I borrowed it from work, but found it was
damaged. They said at work to throw it out, so I thought I'd give
repairing it a go. So that is what I did. Took me half an hour or so.
You are making me think there. I have several fans that are from
professional companies, with data on noise level. If I know a fan
produces x dBA in free air, and I did this in the garden, I wonder if
that would work? It's not going to be to the accuracy of the National
Physical Laboratory, but outside must be a pretty good representation of
an anechoic chamber, as there will be little room for reflections.
I have a few fans around that I could find out noise data on. I might be
able to get some idea of the accuary if a few were compared.
> Or, you can buy the
Radio Shack are not here in the UK any more. It used to be Tandy, but
they don't exist any more either.
Maplin is an option, and I know they have a meter, but it is around $100
if converted to US Dollars, so not exactly cheap.
I bet that you find most of the noise is drive noise. I have an Ultra 10
and a Blade 1000 here, and both are pretty quiet with the drives removed.
(REALLY quiet compared with the 1U Linux servers). I think this is just
because they have so much room for airflow inside. Most of the noise they
do produce is low frequency stuff... the whine from the drives is much more
annoying.
You _might_ be able to find some commercial external SCSI cabinets that
will cut the drive noise. You could take all four drives and put them on
the external buss if you aren't desperate for I/O bandwidth.
--scott
In article <4244caa0@212.67.96.135> nospam@nowhere.com writes:
If I had written "cherry" I would have meant very good. I wrote
"cheezy" which means really cheaply made. I remember the Calectro
brand at my local electronics parts place (when we still had one) and
they cost about $10 in the '60's.
Even if you have a pretty quiet room (other than the computer), a
sensitive SPL meter will read in the 20-30 dB range. Turn on the
computer and you probably won't see the pointer move any more than its
random movement with the computer off. Unless of course your
"computer" is like the rack full of disk drives and old Sun
workstations like my friend Don has. It's hard to carry on a
conversation in the same room.
Does the data say at what distance from the fan (and which
direction) the noise was measured?
>> Or, you can buy the
You could perhaps order online, I suppose they'll ship it over the
pond, thought the current price of USD $39.99 isn't quite as cheap as
the 'twenty bucks' it used to be:
This looks like a different product from a few years ago which was
in a much more rectangular shaped case, but the operational features
appear to be the same - it's probably the same electronics, though
perhaps made with SMT.
Looking at the odd few data sheets on the Papst site (I know I have
several of their fans) the answer is no.
although that would mean buying the standard. I'm not going to do that,
You probably think I'm mad, and the easiest answer is to buy a cheap
meter. But I'm
a) Someone who does not like spending unnecessarily.
b) A PhD scientist who enjoys a technical challenge.
c) No requirement for any great precision. In fact, qualitative, rather
than quantitative measurements would do fine for me, but some
measurement of the latter would be nice to have.
