recently i acquired a fisher 400 tube receiver in great condition , all
tubes light etc but no sound at all anyone give me advice on what to check
email me at hydebee@chartertn.net
In article <_wJ2e.324$JE7.195@fe06.lga>, Hydebee <hydebee@chartertn.net> wrote:
Well, I'd start checking out the B+ and making sure the rectifier tube is
good, then working my way through the output stage. These things are basically
very easy to work on and your local TV repair shop should be able to deal
with it. They have a couple odd things here and there (like filaments being
used as cathode resistors) but for the most part they are straightforward
and docs are easy to get.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
On Thu, 31 Mar 2005 05:14:45 GMT, SSJVCmag <ten@nozirev.gamnocssj.com>
wrote:
>> ... They have a couple odd things here and there (like filaments being
>THAT¹S interesting...
It's in the Big Red Bible, a GE amp thingy, but I don't remember it
in Fishers. I do remember a DC filament supply being used for bias,
but please, don't make me look it up.
Anyway, my off-the-cuff guess is that the OP doesn't have his
speakers connected. It's *not* obvious or trivial on these old
guys. Sometimes output transformer commons float from ground,
or other gotcha's. Sometimes one speaker output will run through
a polarity reversing switch. Stuff like that. Do you get headphone
output?
Good fortune,
Chris Hornbeck
6x9=42
"Right, the DBT is for all intents and purposes vastly superior to
casual listening."
In article <BE70F175.4400%ten@nozirev.gamnocssj.com> ten@nozirev.gamnocssj.com writes:
> ???! THAT'S interesting...
This wasn't all that uncommon. It saved a part and got DC on the
filaments of tubes in applications where AC on the filaments might
introduce hum. But it means that when the filament opens up, you have
two problems - the tube failure and the failure of the circuit
depending on it for proper bias. And vice versa.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
In article <_wJ2e.324$JE7.195@fe06.lga> hydebee@chartertn.net writes:
That's an interesting description of "great condition." Does that
version of our language come from too much shopping on eBay?
SSJVCmag <ten@nozirev.gamnocssj.com> wrote:
>On 3/30/05 10:07 PM, in article d2fpgp$lgu$1@panix2.panix.com, "Scott
I'm not sure why Fisher did it. The same trick is also used on some
phantom-powered mikes using submini tubes, and I know it was done there
for efficiency.
--scott
"Scott
being
there
> for efficiency.
> --scott
I think because they wanted to run the filaments on DC to reduce hum
and it was not easy in those days before transistors and silicon
diodes to build a low volatge realtivly high current DC power supply
that is well filtered. It took big caps and or inductors.
