Yes No
Ads
Tom's Hardware > Forum > Video Games > General Discussion > The Sims 2 Installation Problem
Forum Video Games : General Discussion The Sims 2 Installation Problem
Archived from groups: microsoft.public.games (More info?)
Okay, this might take awhile to explain.
I tried to install The Sims 2 onto my Gateway 450XL laptop, with no luck.
At first I would let the cd auto-play, and the first setup screen popped up
asking me for a language. I would precede to pick English and press next.
After this nothing would happen. No error messages would pop up or anything.
I tried for several days to contact EA's non-existant technical support, and
finally decided to delve into it myself. I know a good deal about computers
and thought that maybe with time, or some luck I would find out what was
keeping this game from installing. I did some research and realised that
after pressing next on the setup menu of the The Sims 2 installer, that
dwtsn32.exe would open an infinite amount of applications of itself. I went
to the windows website a found out how to disable the program (yes I backed
up my registry). In hopes that this would fix my problem.
Now when I try to install the game, the first screen pops up, I press next,
and I get this message
"Autorun7: Autorun.exe-Application error.
The instruction at "0x7ffa302d" referenced memory at "0x7lab5690". The
memory could not be "read".
Does this mean that I have a problem stemming from Autorun.exe?
I have had several trojan's and worms present on my system within the past
6-12 months. I thought that I removed them all, and I cannot find any traces
of anymore on my system. Will I have to do a repair install on my system, or
a total reinstall?
Thanks so much!!
Jessie
Reply to Anonymous
Hi Jessie,
If you have windows XP, it's worth it to do a repair ...
How To Repair Windows:
Unplug from your Internet connection, and then repair Windows:
using this method: http://michaelstevenstech.com/XPrepairinstall.htm
Afterwards, boot up your system, turn on your XP Internet Firewall,
plug back into your Internet connection and install all Critical and
Recommended updates from: http://windowsupdate.microsoft.com
Cheers, Windows XP MVP Shell / User
Jimmy S. http://mvp.support.microsoft.com
Game FAQs: http://support.microsoft.com/default.aspx?scid=FH;[LN];gms
Visit my Zone.com / Gaming Helpsite: http://nibblesnbits.tk or Call / Contact
MS Support at: http://support.microsoft.com/defau [...] ;en-us;top
My advice is donated "AS IS" without warranty; nor do I confer any rights.
_________________________________________________________
"JessieRose" <JessieRose@discussions.microsoft.com> wrote in message news:DDBACEC7-970E-4E22-BD60-D90FD1A50F17@microsoft.com...
| a total reinstall?
| Thanks so much!!
| Jessie
Reply to Anonymous
- 0 +
First when i install the sims2 I was so lucky,because it has no error but when I opened and played it there was a problem,the walls are color red and it cannot preview the designs for the walls and when my friend install it too to their laptop it has no error too in installing,but when she played it it has a gleach but no red walls,so in that case I install again tha game but while installing it has an error,it says
An error occured while trying to copy a file:
The request could not be performed because of an I/O device error
So what it means and what i would do? PLS. HELP ME
THANK YOU
MICAN
Reply to mican
- 0 +
sims 3 is much better than sims 2.. hahaha..
Reply to jokrow
- 0 +
New necro record?
Reply to pr2thej
- 0 +
whats up can anyone help me???Pls rply fast I need to install my game
Reply to mican
There are 1519 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Headset 80 bucks?
By fantastik250, 12 hours ago:
You can look at Corsair vengeance 1300 headset (vertical positioning, only up and down),...
Best offers
Top experts
