Archived from groups: alt.cellular.sprintpcs (More info?)
"David G. Imber" <imber@maniform.com> wrote in message news:50bj71558ockvga61ch0ll2aeqbupph2mh@4ax.com...
> Hi:
> My battery doesn't seem to hold a charge quite as well as it
> used to, so it may be time to replace it.
> The OEM replacement on SPCS's site is $60. It's a standard
> li-on battery as far as I know.
> Does anyone have any recommendations for either the same
> battery at a lower price or a better battery?
> Thanks in advance, DGI
I've bought cell phone batteries from eBay, and they worked fine.
David G. Imber <imber@maniform.com> wrote:
> Hi:
Have you tried draining and fully recharging the battery?
Kevin M.
"Know your enemy, and know yourself; in one-thousand battles
you shall never be in peril." -- Sun Tzu, *The Art of War*
"Contentment... Complacency... Catastrophe!" -- Joseph Chevalier
On Thu, 5 May 2005 17:34:57 -0700, "Kevin M." <youwish@imaspammer.org>
Yes, and when the recharge held for only a number of days
after that, despite very limited use, I decided battery must be
getting old. It still has a good deal of life left, I'm just asking
now so that I can make an educated purchase when the time comes.
I've had good luck buying from cellularaccessory.com. No genuine Sanyo
battery, but they have a low price on an aftermarket battery. 1400mah,
Cinco de Mayo Sale Price: $17.95
David G. Imber wrote:
> Hi:
Are the 4920 batteries that you link to the standard size ones, that
are the same size as those that come with the phone ? Or are they the
oversize ones that change the dimensions and shape of the phone ?
JBJ
On Fri, 06 May 2005 06:32:04 GMT, Frank Harris
>http://www.cellularaccessory.com/rl4920battery.html
>> Hi:
