Closed Solved
base system device driver
where can i download it and what is it for. also it isn't installed on a fresh installation of windows 7 or when the system is updated.
5 answers Last reply Best Answer
More about base system device driver
  1. Please visit the manufacturer's website to download the drivers for your device. You can use google to find the manufacturer's website if you do not know it. In the support section download the drivers for your specific make and model of the device for your version of Windows.
    Note: If the manufacturer only lists drivers for Windows XP and not for Windows Vista or Windows 7, that means the device is unsupported or incompatible with the unlisted operating systems.
    If you do NOT know the make & model of your device you can Search by Vendor / Device code as shown in device manager.
    In the device manager, for the device you need driver for, Right click properties for the device, go in details for the device driver.
    You will see a code like per example VEN_8086&DEV_27D8&SUBSYS...
    The VEN code means vendor and the DEV code means device: in this case the vendor is 8086 and the device is 27D8.
    Once you have the two codes, go to
    Enter the two codes and you should get the name of your hardware. From there you can search for a driver download for your hardware.
  2. Best answer
    I saw this on a Dell laptop.
    I forget which driver solved the problem. As mentioned above you must use ONLY the drivers for your EXACT laptop and version of Windows.
    Additionally, many laptops have multiple options such as three video cards so you must know which ones you use.
    Download and install:
    1) the main chipset driver (i.e. Intel INF or whatever)
    2) audio driver
    3) network driver
    4) Media card driver
    5) additional software for your laptop
    I think the problem I had was fixed by the Media card driver (SD-card/CF).
  3. i don't get why newer operating systems don't have all the stuff you need and you manually have to do it online and pay for it. your lucky if its free these days
  4. Best answer selected by dan macduff.
  5. thank you photonboy it was the problem
