Filter and sticky keys problems
olled
Hello,
I have the same problem with pauline_49. Shift key are good. No faulty wiring or anything that stuck the shift key but still had this problem like Pauline_49.
Please give me an advise. Thanks.
Olled
How To Ask Questions The Smart Way
Before asking a technical question do the following:
Try to find an answer by searching the forum.
Try to find an answer by searching the Web.
Try to find an answer by reading the manual.
Try to find an answer by reading a FAQ.
Be precise and informative about your problem
Describe the symptoms of your problem or bug carefully and clearly.
Describe the environment in which it occurs (machine, OS, application, whatever). Provide your vendor's distribution and release level (e.g.: “Windows XP SP1”, “Ubuntu 12.04 32bit”, etc.).
Describe the research you did to try and understand the problem before you asked the question.
Describe the diagnostic steps you took to try and pin down the problem yourself before you asked the question.
Describe any possibly relevant recent changes in your computer or software configuration.
If at all possible, provide a way to reproduce the problem in a controlled environment.
olled
I find no answer in the link provided. I did try what the other member suggest but to no avail it doesn't work. Maybe, I'll just try to have it repaired by another technician. Thanks
