Desperate for info on Unitor 8 Mk II power supply
Last response: in Home Audio
Anonymous
Power supply Expert
Archived from groups: rec.audio.pro (More info?)
I've lost the power supply for my Emagic Unitor 8 Mk II, and
neither the manual nor the box say what the correct power adapter
specs are (volts, or whatever). If you have a Unitor 8 Mk II,
could you take a look at your power supply and tell me what the
volts and amps are on it? I'd be incredibly grateful....
Posted with NewsLeecher v2.1 Beta 1
* Binary Usenet Leeching Made Easy
* http://www.newsleecher.com/?usenet
Anonymous
Power supply Expert
>From the power supply:
Unitor8MKII
Model: A30910C
CLASS 2 Transformer
Input: 120V 60Hz 15W
Output: 9VAC 900mA
Ask the community
