k, I <i>was</i> going to get two CompuNurse dual temp monitors to monitor case temp, cpu temp, gpu temp, and water temp for my WaterCooling setup (sooooooooon). Then I'm lookin at the price - $14 for one, aka $28 for the two i want... then I'm thinkin, maybe it would be worth it to go with a multi-function panel for the same price, and get all the temp monitoring from there... thing is, i've got a vantec fan controller, and i like it - i don't want thermally controlled fans, no thank you. therefore, f#ck the usefullness of a digidock5 or whatever, i won't use its primary functions... if someone can point out something good - i know that Directron.com has a bunch, I'd really appreciate.. again, minimum 4 temp probes that i'll actually be able to see, not just temp probes for fan speed varying... thanks
LOL... don't worry. In most of the cases I use my brain. I was just searching some stores for different temp/fan controllers (they're often listed in the same category) when I saw this one... but I forgot you where searching for a temp controller while this was only a fan controller.
My dual-PSU PC is so powerfull that the neighbourhood dims when I turn it on
