Tom's Hardware > Forum > Mobility Networks > Sprint PCS > Earpiece audio quality - Sanyo 4920
Forum Mobility Networks : Sprint PCS - Earpiece audio quality - Sanyo 4920
Archived from groups: alt.cellular.sprintpcs (More info?)
Hi:
My wife and I have been using the Sanyo 4920 since it came
out, and have used Sanyo phones for the past 4~5 years.
I'm thoroughly happy with the Sanyo's form, functions,
reliability, reception and signal holding ability. Indeed, for those
things I have no doubt it's the best cellular handset I've used
(although the 4700 was equally good, and I don't take advantage of
Vision, Ready Link, or anything else introduced since then that
distinguishes the 49XX line).
There's only one thing that disturbs me about this phone. The
earpiece audio is just not crisp. It's certainly loud enough, but not
well-defined. Too often "I'll meet you at the corner of 47th and 9th
avenue" sounds like "Aahheeeuuuaaacorophilaseanai" (you get the idea).
Of course, a lot depends on the other party's instrument. But
I've had this phone long enough to tell when it's my handset.
Two questions:
* I've heard this reported by others on occasion, but is this a
generally accepted assessment of the 4920?
* Are any of the other Sanyo phones better in this area? I don't
remember my 4500, 4700, or 4900 phones having this problem. They had a
somewhat different problem, which was that it was difficult to find
the earpiece "sweet spot". Sanyo seems to have overcompensated by
making the spot easier to hit, but increasing the audio signal to the
point where it distorts.
I have tried cutting the earpiece volume from the default "4"
to "2". Paradoxically, decreasing the volume increases the clarity,
but that's obviously not a great solution.
Thanks in advance for any observations and advice.
DGI
Sponsored Links
David G. Imber wrote:
> Hi:
idea).
> Two questions:
a
> DGI
Yes the more recent Sanyos don't sound as good as the older generation
but they're starting to get better again with 2300 and 5600 models.
The 8200/7300 phones probably have the worst earpiece sound out of any
Sprint phone ever. The 4920 is a little better than those at least.
Reply to Anonymous
Thank you. I was thinking that if I got new phones, they might
very well be 2300's, and I was specifically wondering about the sound
on them. I would definitely stick with Sanyo in any case.
DGI
Reply to Anonymous
Actually this was a known issue on the 4920s and a reported software upgrade
(preformed free of charge at a Sales AND Service location) fixed this.
"David G. Imber" <imber@maniform.com> wrote in message
news:rtt291dcl4su0c3cmuhsu5jcg1ig1ln43k@4ax.com...
> DGI
Reply to Anonymous
On Mon, 23 May 2005 12:39:29 -0400, "Bill Marcus"
My firmware is up to date, but I don't think that the upgrade
addressed that specific problem (fuzziness). I think the audio problem
addressed by the upgrade had to do with echoing. Could be wrong. In
any case, the problem did not change after the upgrade (and actually,
it's a pretty subtle problem - the phone is still head and shoulders
over every other phone I've had).
DGI
Reply to Anonymous
You are correct the 4920 software revision was for the echo problem and
not overall sound quality.
Reply to Anonymous
There are 1309 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
