Tom's Hardware > Forum > Audio > Pro Audio > Multiface power supply
Forum Audio : Pro Audio - Multiface power supply
Archived from groups: rec.audio.pro (More info?)
My Multiface power supply died during a very time-critical job. My local
electronics store only had a supply delivering 0.7 amps (rather than 1.25 on
the original) - I bought this and it seems to work. Am I likely to have
problems
with the lower current of this supply?
Another store that I did not have time to get to had one delivering 1.5
amps. Would this be preferable or is it too high?
Sorry can't post to the RME news server for some reason!
Sponsored Links
"Karl Engel" <karlengel_AT_excite_DOT_com> wrote in message
news:425252c0@dnews.tpgi.com.au...
on
> problems
1.5 Amps can't hurt.
Predrag
Reply to Anonymous
>problems
Depends on how much current the Multiface wants. If it wants more than 0.7
amps, the supply will probably overheat and eventually fail.
No, you could use a supply rated for a thousand amps and you'd be fine.
And it would probably run very cool.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
In article <425252c0@dnews.tpgi.com.au> "Karl Engel" <karlengel_AT_excite_DOT_com> writes:
> problems with the lower current of this supply?
If it works, it will probably continue to work. But probably better to
get the correct replacement on order.
You can't have too many amps, in this context. You would have been
safer with that. However, there's a lot more to plug-in power supplies
than what meets the eye. With the limited knowledge that you show from
your posting (and you might know more than you show) you were lucky.
First of all, some are AC, some are DC, and they're not
interchangeable. There are two possible ways to wire the connector as
to which terminal is positive, and both are used. Then there are
ripple and grounding considerations.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
mrivers@d-and-d.com (Mike Rivers) wrote in message news:<znr1112700012k@trad>...
Hi Mike, I'm always happy to admit the limits of my knowledge! In
this case I knew the supply needed to supply DC 12V with the tip
positive - mainly coz it said so on the old one!
RME support got back to me to say the Multiface really needs 800mA so
what I have is a little shy of that. I didn't know you could have
lots more current without causing a problem, thanks for confirming
that.
What's throwing me is that the old power supply doesn't work when I
first plug it in, but leave it on for awhile and it comes good (the
little light on it comes on full strength). So it's not failing as
such, but needs a push to get going! A sign of imminent failure
perhaps, or does this indicate something else?
Reply to Anonymous
"Karl Engel" <karlengel@excite.com> wrote in message
news:e6dc7d48.0504051455.1c4664b8@posting.google.com...
> that.
When a supply says "1.5A" on it, that refers to how much it's capable of
supplying. If the Multiface only draws 800mA then that's what the 1.5A
supply will give it, and it'll be coasting comfortably. So not to worry -- a
supply rated for higher current than you need is always safe, and probably a
good idea in terms of reliability, heat generation, etc.
Peace,
Paul
Reply to Anonymous
There are 1145 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
