Archived from groups: rec.audio.pro (More info?)
Hi, I've been having a huge clicking/popping problem with my PC.
Before I blabber on, here's what I have
AMD 3GIG
512MB RAM
80G HDD (for audio)
40G HDD (for windows)
Delta 1010 (rack version)
Cubase SX 2.
It suddenly started after Christmas, initially I thought it was
graphics related, as there would be a click every time I zoomed in and
out in Cubase, or maximised/minimised a seperate window while keeping
Cubase running. Of course, there was also the clicking whilst
recording which was soemtimes being captured in the recording, and
sometimes during playback.
I was getting really pissed off after about a month, so I ordered a
new graphics card, which did nothing to remedy the problem. I then
re-formatted, which I thought had done the trick, and since then the
problem has been slightly better, but it's still there, nagging away.
Decreasing the graphics resolution to 16 bit helped somewhat, but I
shouldn't have to do that with a Radeon 9600 256MB.
Here's what I've tried:
Changing the buffer (obviously)
Disabled system restore + auto updates
Changed processor scheduling to background services
Maximised the swap file
I know it's not something external like a heater or a light.
Updating the Delta 1010 drivers.
Checked IRQ, I can't see the PCI card for the Delta101 listed at
startup, I don't think it's sharing anyway.
Any ideas would be appreciated
Hi, Owen:
I'm certainly no expert on computers or electronics, but as I was
reading your post, there is one thing that I noticed was missing: any
mention of a good power conditioner or UPS (uninterruptible power
supply), which can help a lot to minimize many kinds of AC "noise
pollution."
What is providing power to all of the elements of your recording
system?
I am using a decent-sized UPS made by ADC. My computer is plugged
directly into this UPS. The UPS also powers my Furman digital power
conditioner, which is where all of the other elements of my system are
plugged in. My Furman power conditioner has additional power filtering
especially for digital components.
I haven't had a single noise problem since I plugged my system up to
these sources. I'm not saying that any of this has to do with your
problem, but it's worth a try.
On 5 Apr 2005 12:57:51 -0700, owenoftheshire@gmail.com (Owen Shiers)
>AMD 3GIG
>512MB RAM
>80G HDD (for audio)
>Cubase SX 2.
>Cubase running.
Is something disabling/enabling the soundcard? Did you install any
new software/hardware around the time this started?
That's a symptom of one or more 'background tasks' taking up CPU
time that weren't there before.
There's also a graphics acceleration parameter in the Control
Panel->System->Performance tab. Turning it down/off makes the CPU do
more of the screen drawing which slows down redraws, OTOH it will be
interruptible by other tasks (such as audio), whereas a graphics card
operation might not be interruptible. At least that's what I read
before, I dunno. Regardless, it seems like installing a new graphics
card is an extreme and unneccesary solution.
The one thing you forgot to tell us is what OS this is: (the legacy
series): 98, 98SE, ME, or (the NT series), 2K, XP? (did I miss one?)
Press ctrl-alt-delete and see what all is running. There's likely
lots of unneccesary things. Do a Google search for each running entity
to see what it is and whether you can safely remove it. Run msconfig
to disable these things from running at startup. My cheap HP
printer/scanner software loads in about a half-dozen things, and none
are neccesary for just printing, but they do take up significant
resources while 'inactive' in the background.
Some of what's running could be adware/spyware/viruses/general
malware, and that stuff is not well written, they don't bother to be
careful about resources. I've seen some P2P program, IIRC it was
Gnutella, running on a newish XP system, and it just about brought the
machine to a halt, the computer was completely useless for doing
anything else while it was running 'in the background.'
http://mindspring.com/~benbradley
> AMD 3GIG
> 512MB RAM
> 80G HDD (for audio)
> Cubase SX 2.
and
Hi Owen:
I'm sorry that your having this problem, it is so frustrating. I had
the same experience with an m-audio soundcard, and two things that I
tried seem to cure the problem.
Firstly, changing the computer to run in 'Standard mode' rather than
ACPI. There used to be a help section on the m-audio website to show
how this can be done.
Secondly, I tried using a different driver, the asio4all...if you do a
search you can find this. It is (or used to be) a free download. I
couldn't get the m-audio asio drivers to work with wavelab (and still
can't!!)
You can check the IRQ allocations on the pc by going to Device
manager/click on the 'view' tab then select 'resources by type' and
then 'irq'. This will give you a list..
Hope that this helps a bit,
Best wishes,
David Caswell
> AMD 3GIG
> 512MB RAM
> 80G HDD (for audio)
> Cubase SX 2.
I had almost the exact same problem with my delta 66 a few years back. I
updated the drivers and that fixed the problem. Obviously this isn't
working for you. I would make sure that Cubase is using the correct ASIO
driver by going the the device setup window...I forget exactly how to
get there but I'm sure you know the one. You should be using the M-Audio
Delta ASIO.
If it started suddenly and without warning, I would be highly suspicious
of spyware eating up CPU cycles. Download Ad Aware AND Spy Bot and run
both of them....I believe Norton or McAfee also makes a free one, the
more you can run the better....if spyware is found, and upon research it
turns out to be really nasty stuff, you might have to take drastic
action like re-installing windows or even backing up all your files,
formatting and starting from scratch.....if this is the case, in the
future, use your DAW for AUDIO ONLY and keep other programs to a bare
minimum.
If you are running Win2k/NT/XP you should be able to find CPU bandwidth
hogs quite easy and narrow down any process, spyware or otherwise which
is eating up cycles.
You could also try completely removing the 1010's PCI card from your
system, uninstall all delta drivers/software and re-install from scratch.
You might also want to uninstall and re-install cubase while you're at
it just to be sure, which is actually quote easy.
It sounds like you've tried everything else I could think of. I really
think your problem is somewhere in the drivers or spy/malware. Good
luck, I know how frustrating this exact problem can be so I hope to hell
you figure it out. Keep us updated! Thanks!
Jonny Durango
"EADGBE" <hwbosshoss@aol.com> wrote in message news:<1112748791.570492.104500@f14g2000cwb.googlegroups.com>...
> Hi, Owen:
> pollution."
> system?
Hey, thanks for the reply. I know that the building is on the end of
the power line, and we have had fluctuation problems in the past
(which we havbe complained about and they seem to have remedied. I
might look into a UPS, although it wouldn't explain why the problem
started occuring around Christmas time, as there's been no change in
supply for the last two years. I'm still convinced it's a computer
related problem, but if all else fails I may look into it as a last
resort!
What kind of noise problems were you getting before you installed the
UPS and the power conditioning?
Cheers
Owen
> > AMD 3GIG
> > 512MB RAM
> > 80G HDD (for audio)
> > Cubase SX 2.
Hi there - what Delta driver are you running?
I had best luck with an older driver : Delta_29x12_Pro.EXE
Maybe rey Googling for it - it isn't on M-Audio's Site any more (at least I
don't think it is.....)
Good luck!
Geoff
Owen:
I use some outboard signal processors with my DAW. (Plug-ins are great,
but there's nothing like the "old school"!)
I was getting some hum showing up on some tracks I recorded with the
outboard processors, even though ALL items were plugged into the same
surge protector.
I did some reading, and found that even a "good" surge protector
doesn't actually "condition" the AC power. It simply protects against
power spikes. In other words, I had spike protection, but I was still
getting the same "dirty" power with the usual AC line noise.
Even though it sounded like a gimmick, I went ahead and bought a power
conditioner, and VOILA! All of my line noise was gone. It really made
me a believer.
Is it a desktop or a laptop (I didn't notice if you mentioned it)? Many
laptops cannot reset IRQs. Mine has the the USB, the IEEE 1394 and the
Radeon video card all sharing the same IRQ. Brilliant!
It did work fairly well for a few months, however.
I had some click/pop issues using SX-1 which eventually became crash
problems. Tried many of the suggestions mentioned above, all of which
are valid. I ended up having the M-board replaced. When the problem
returned, my warranty replaced the RAM, HD & CPU. When I re-installed
the OS and the computer went to BSOD then wouldn't boot in any mode
(that same day), I contacted the Manufacturer (Dell). This all over the
course of a few months. I am currently awaiting the arrival of a new
laptop. We shall soon see if it is destined to compute only word
processing and newsgroup browsing at which point I'll break down for a
dedicated desktop, with no absolute guarantees. Hope yours is a better
scenario.
IOW, hang in there. It's not a perfect science & I feel your pain.
peakester
P.S. I also own an Alesis HD-24 which is close to bulletproof but not
as versatile.
Hum is different than clicks and pops. I'd be willing to bet better AC
won't matter. I have heard of occcasional mismatches between sound cards or
hard drives and certain mother boards. Not an easy solution, but if it is
the cause, looking in the wrong place won't help.
Julian
news:1112748791.570492.104500@f14g2000cwb.googlegroups.com...
> Hi, Owen:
> pollution."
> system?
Hi Owen. IT is my day job, recoding my weekend passion. I think I can
probably help you, but I need some info...
What Motherboard/chipset are you running?
What type of hard-drives? IDE or SATA?
What if any network card do you have?
Are you running any wireless network cards?
Many of the early generation PCs with Serial ATA have 3rd party controllers
haning off the PCI bus on the main board. This often results in PCI bus
saturation and I guarantee that this will cause pops and clicks in your
audio. The Delta 1010 card is particularly susceptable to this, so you need
to be careful in your Motherboard selection, especially if you run SATA
drives.
To figure out your IRQ assignments in Win XP, go to Accessories|System
Tools|System Information, expand out "Hardware Resources" and click on
"IRQs". What IRQ is the delta running, and is it shared with anything else?
I'm assuming that you are running XP.
The advice about running your PC in "Standard PC" mode is only good if you
have an older I/O PIC as your interrupt controller. If your system has (and
probably will if it's a late model AMD board) an I/O APIC, you should be
running in ACPI mode to get better distribution of IRQ resources.
If minimising/maximising/opening/closing windows adds to the clicks, try
this...
Go to "System" from your control panel, click on the "Advanced" tab and then
click on the settings button in the "Perfomance" area at the top. On the
"Visual Effects" tab choose the "Adjust for best performance" radio button.
This will cause Windows to look ugly, but you will know straigt away if
fades and animations are playing a part in your audio problems. Don't
worry, you can turn a lot of the features back on later to make windows
pretty again, just leaving out the animations and fades.
Owen, please feel free to email me privately at
bill.ruys@DELETETHIS.siliconaudio.co.nz and I will try to help you. I have
gone through the pain of clicky audio with the Delta 1010 an other cards, so
I feel your pain!
Cheers,
Bill Ruys.
"Owen Shiers" <owenoftheshire@gmail.com> wrote in message
news:4ce48aaf.0504051157.76af4bb5@posting.google.com...
> AMD 3GIG
> 512MB RAM
> 80G HDD (for audio)
> Cubase SX 2.
> drives.
> this...
can you suggest some budget MB's that don't have this SATAturation
problem? I really like Abit and Soyo for price/performance. Tks!
Jonny Durango
"Bill Ruys" <bill.ruys@nospam.siliconaudio.co.nz> wrote in message news:<zb75e.16726$1S4.1697255@news.xtra.co.nz>...
> drives.
> this...
> I feel your pain!
> Cheers,
> Bill Ruys.
> > AMD 3GIG
> > 512MB RAM
> > 80G HDD (for audio)
> > Cubase SX 2.
Thanks for the reply. I've disabled all animations and fades
(basically just left on the blue taskbar) but I do get clicks and pops
when I minimise cubase, or open up internet explorer or something.
I also ran Spybot, AdAware and AVG today. They picked up a few minor
things, but it didn't make any difference.
Also, why would my processor say 1.47ghz in My Computer>Properties
when it's a 3 GIG? Is this the motherboard speed or something? I'll
get back with more details tomorrow.
Cheers
Owen
Lots of good advice here.
Someone in another thread mentioned that clicks and pops can be caused
by inadequate latency settings for PCI devices at the Bios level.
Here's the link
http://www.mark-knutson.com/t3/
My Motu HD 192 system is prone to these nasty annoyances too, so I
jumped on this solution hoping for afix. Sadly, it didn't work for me,
but maybe for you.
Harry
> Cheers
Sounds like your BIOS has reverted to it's defoult settings. You will
need to reboot into Bios and set the FSB speed and/or multiplier. It's
probably set at 100mhz. This can happen after a bad crash or hardware
swap.
Do you have a video card, or shared video? Shared video causes problems.
Check the video aperture size while in bios, shouldn't be set higher
than 64mb.
>>drives.
>>this...
>>I feel your pain!
>>Cheers,
>>Bill Ruys.
>>>AMD 3GIG
>>>512MB RAM
>>>80G HDD (for audio)
>>>Cubase SX 2.
> Cheers
> Owen
Wow, that's definately a BIOS issue....I would follow jackfish's
suggestions and also disable any onboard sound. It sounds like you may
have tracked down the problem.
Jonny Durango
Or try a different sound card that might not have a BIOS issue. Maybe Echo?
Julian
jackfish <jackfish@north.org> wrote in message news:<jackfish-55C859.23262007042005@news.mts.net>...
> > Cheers
> swap.
> than 64mb.
No, it's not a BIOS issue (I did think it might be this originally)
it's set at auto and says it's running at 3Ghz. I'll open up my PC
this afternoon and jot down the brands of CPU, RAM, motherboard etc.
Right, here's some more details that I've gathered from looking at the
chips
CHIP
AMD Athlon Mobile 1700 - 1.47Ghz
Thoroughbred Core
L2 Cache - 256KB
http://www.theshiers.plus.com/screen.jpg
Does this mean the actual speed of the chip is 1.47ghz? In the CPU
section of the BIOS I have:
CPU 3000A+ (Note: this section is un-editable)
DRAM Frequency Auto
MOTHERBOARD
Model M825 v7.2c
Motherboard Chip: VIA VT8235
http://www.via.com.tw/en/products/ [...] ge/vt8235/
GRAPHICS CARD
Radeon 9250 256MB AGP (running dual monitors)
SOUND CARD
M-Audio Delta 1010 (driver version 5.10.00.0048)
Operating System: Windows XP Professinal (With SP2)
Here are some of my BIOS (AMI Bios 686) settings which I thought might
be relevant:
Plug and Play Aware O/S Yes
Share Memory Size None (I presume this is the inbuilt
graphics card)
Primary Graphics Adapter AGP
Allocate IRQ to PCI VGA Yes
PCI IDE Busmaster Disabled
AGP Mode 4x
AGP Comp Driving Auto
Manual AGP Comp Driving CB
AGP Aperture Size 64mb
On board FDC Enabled
On board setial port A 378h/COM1
On board IR Port Disabled
On board parallel port 378h
Parallel Port mode EPP + ECP
Parallel Port IRQ 7
Parallel Port DMA 3
Here's a table of my IRQs
http://www.theshiers.plus.com/irq.jpeg
-I have disabled the inbuilt graphics and modem.
-I'm using the inbuilt network card.
-I don't see how changing the PC to run in standard mode will help,
considering the PC is only a year old.
-Windows XP is in its own seperate partition (10GB) and my audio +
Cubase are allocated to a second 80GB drive. Both drives are on
seperate IDE channels to the CD-Roms and are running in DMA mode. Both
drives are IDE.
-I'm not running any wireless network cards.
-System has been adjusted for best performace
-System restore is disabled
-XP Firewall + System updates are disabled
-AVG, Spybot and Ad Aware all come back clean
I have not tried this link:
yet, but I can only see it affecting my soundcard, considering the
graphics card is in the AGP slot.
Right, I think that covers everything. Any help as always will be
gratefully appreciated.
Owen
the
> chips
> CHIP
> Thoroughbred Core
> L2 Cache - 256KB
> DRAM Frequency Auto
> MOTHERBOARD
> Model M825 v7.2c
> GRAPHICS CARD
> SOUND CARD
might
> be relevant:
> graphics card)
> AGP Mode 4x
> Parallel Port IRQ 7
> Parallel Port DMA 3
Did you try disabling the network card ( or connection) before
recording? I found that having an open network connection whilst
recording can also cause clicks and pops.
Do check the knowledge base on the m-audio site, there is a lot of info
on there.
I changed my computer to standard mode because someone told me that
m-audio cards prefer this mode.
Regards,
David Caswell
Both
> drives are IDE.
> Owen
>drives are IDE.
doesn't the application and it's operating system need to be on the
same partition/drive???
this is how I set up my audio,,,seperate partition with stripped down
OS tweaked for audio with audio software only loaded on it with no
internet usage when using audio app's.
dale
"dale" <dallen@frognet.net> wrote in message news:<1113077297.608860.211780@f14g2000cwb.googlegroups.com>...
> >drives are IDE.
> dale
I don't think so. It was on the same drive before and I still had the
popping problem. I tried disabling the network card, that did nothing.
I did have a bit more success with disabling AVG and all its
processes, I managed to run Cubase happily for half and hour without
any clicks whatsoever. If someone could please answer my question
about my chip - is it actually a 3 gig?
Cheers
Owen
no
Ok - latest update. I think the problem was AVG. This would tie in, as
they brought a newer version out around the same time the problem
started happening. I know it's a really obvious thing, but even after
quitting AVG, it still leaves 3 processes running - which were
evidently causing popping + clicking. I'm considering emailing AVG and
informing them.
I have two further questions if anyone is willing to answer:
With regards to my chip (AMD Athlon Mobile 1700 - 1.47Ghz). I was told
it was a 3GIG chip (is the 1.47Ghz another speed?)
Also, I have a Focusrite Twin Trak Pro running though SPDIF into my
Delta 1010, do I leave the wordclock as internal in the delta 1010
settings, or does the Twin Trak need to be set to master, and the
Delta 1010 slave?
Cheers
Owen
There are 1075 identified and unidentified users. To see the list of identified users, Click here.
