I use a turtle beach santa cruz sound card with a 5.1 setup..... My problem i am 99% sure is in the soundcard or software (not speakers). What happens is the sound works perfectly for a while, but randomly when the song changes or the volume is changed on the computer, the left side (both front and rear) will lose most of their volume, and the whole thing sounds really off balance. I can easily fix the problem by just moving a volume knob in the SC control panel, but then when the song changes or volume i have to do it again, it is extremely annoying. Anyone have any ideas at all?? I re-installed card and drivers, didn't work.
Any help is appreciated.
Thanks
-Ethan Samson
esamson@uiuc.edu
AIM - kujorulez
Thanks
-Ethan Samson
esamson@uiuc.edu
AIM - kujorulez
