Can someone explain the difference between these two Corsair Model numbers. Is one better than the other. They are only .50 cents difference in price.
Is one a better performer. I saw these at Newegg.com
Option #1
CORSAIR MEMORY XMS Extreme Memory Speed Series 256MB 32MX64 PC-2700C2PT With Platinum - Silver Heat Spreader OEM
Specifications:
Speed 333 MHz
Organization 32M x 64
CAS Latency 2-3-3-6-T1
Memory type DDR
Part number: CMX256A-2700C2PT Model#: CMX256A-2700C2PT
Option #2
CORSAIR MEMORY XMS Extreme Memory Speed Series CMX256A-2700C2 C2 256MB PC2700 DDR RAM Single-size FASTER 333MHz - OEM
CMX256A-2700C2. DDR, PC2700 32x64, Non-ECC, 184-Pin, CAS2 -Unbuffered Requires DDR supported Motherboard - Lifetime Warranty. Model#: CMX256A-2700C2
Thank You in Advance.
<P ID="edit"><FONT SIZE=-1><EM>Edited by seekie on 05/10/03 02:29 AM.</EM></FONT></P>
Option #1
Specifications:
Speed 333 MHz
Memory type DDR
Option #2
