I fear incompatibility between the Echo and my motherboard (A8N-SLI Deluxe)
and I'm shopping for alternatives before the final verdict is officially in.
The G3G is an *All In One* Solution for a beginning bedroom studio type. The
Delta 44 is not.
The Delta FW-410 is. What do you want and what inputs/outputs do you need?
Archived from groups: cakewalk.audio,cakewalk.general,rec.audio.pro (More info?)
"Papanate" <nospamagain@nc.rr.com> wrote in message
news:425AA446.5F807A80@nc.rr.com...
> Mike Schmidt wrote:
>> Can someone tell me how the Gina3G compares to the following two M-Audio
>> devices?
>> http://www.m-audio.com/products/en [...] -main.html >> http://www.m-audio.com/products/en [...] -main.html >
> type. The Delta 44 is not. The Delta FW-410 is. What do you want
I'm more concerned with the converters, latency, and noise level.
As for the in/outputs, as long as I have 2 ins and 2 outs (although 4 outs
would make me feel more secure) and they're not cheap-ass audio mini-plugs
like you'll find on the Audiophiles (1/4" is the bare minimum) then I'm
happy. Extra points if it can take MIDI like the Gina3G can, but since my
motherboard also provides a gameport slot for it, it's not a must-have. Same
for XLR ins. Not a *must*, but would be nice.
Like I said, the converters, latency and noise levels are my main concerns.
How does the M-Audio Firewire 410 compare to the Echo Gina3G PCI in that
respect?
PS: Echo Support just told me to try another PCI slot on my motherboard, and
if that doesn't work, I'm S.O.O.L... nice. I'll try tonight when I get back
home, but I fear that I'm screwed. Hope the store takes the Gina back.
> respect?
All about the same specs between the two.
Well not exactly. See my other post in your thread about dumping the Gina, you
have more than a few options. Most likely scenario here is there is some
conflict between the on-board games stuff and the Gina.
Most of the stores, online and otherwise will take the boards back. Some will
charge a restocking fee. If you are going to go that route call up M-Audio, Echo
and RME and ask them specifically about your motherboard and their cards.
news:425AD958.2A3150E7@nc.rr.com...
>> respect?
Is there any advantage/drawback going from PCI to Firewire (which is what
I'd be doing by dropping Echo and switching to M-Audio's Firewire 410).
As for contacting Echo, like I said, I've already done that. I will,
however, contact M-Audio before buying anything of theirs, to not make the
same mistake again.
"james" <fishbowl@conservatory.com> wrote in message
news:LiB6e.1942$63.196@fed1read02...
> In article <d3emo8$b9g$1@domitilla.aioe.org>,
> Since the firewire controller is itself a PCI device, firewire can
> deliver, at best, some fraction of PCI throughput.
> The advantages of using Firewire include matters of convenience, power
> supply, cable length, hot-pluggability, and so on.
Oh! That makes sense.
Would I notice any difference in latency settings in Sonar by switching to
firewire?
Another advantage is that it puts the audio circuitry farther away from
the computer's digital switching, which may keep some noise from getting
coupled into the system.
Another possible advantage might be that it lets you put the converter
closer to the signal source, getting into the digital domain sooner and
again avoiding some noise risks.
Another possible advantage, depending on the device, may be portability
between operating systems. It may be easier to find Linux drivers for
external boxes than for things which plug directly into the bus, for
example, just because the protocol tends to be better documented.
>respect?
Looking at the specs of M-Audio FW 410: signal-to-noise ratio: 107 dB
that about 18 true bits. Nothing is said if this is for output, input,
or both.
The Gina3G specs are 114 dB output, 110 dB input, thus 19 bits for output,
18 bits for input.
"SSJVCmag" <ten@nozirev.gamnocssj.com> wrote in message
news:BE81B4D6.56B4%ten@nozirev.gamnocssj.com...
> On 4/12/05 9:40 AM, in article 1kjn51dpb125vnil2t23h6nrvqn1gelv7p@4ax.com,
> Folks, let's all edit the header on this thread and kill the crosspost ?
> At least so it stays in the CAKEWALK Zone.
> It's easy!
> It's Fun!
> It shows you're smarter than the kiddietroll that
> put all those unrelated NG's in there in the first place!
> Go for it!
> Thanks!
They weren't unrelated. And forgive me for questioning your credibility when
you just spammed said groups 5 times in a row with the same message.
Either way, the threads are over. The problem was solved, as was posted. So
not only are you spamming all the groups to ask that they stop being spammed
to, but you're actually doing so after the threads were done anyway.
