Tom's Hardware > Forum > Audio > Pro Audio > Double Bass... two different mics or same?
Forum Audio : Pro Audio - Double Bass... two different mics or same?
Archived from groups: rec.audio.pro (More info?)
Hi. I have a D112 that I always use for kick drum miking which I'm
quite happy with. However, at times I find that one such mic isn't
enough for a kit with two kicks.. or if I'm recording two bass cabs,
etc. I'm thinking of purchasing another D112. Howere, the Shure Beta52
looks pretty interesting. I do like to have a variation of mics to
choose from. But should I use the same two mics for such applications
as double kick? I know that a variation in the sound of two kick drums
is desirable.. but I don't know if I should be getting that variation
solely from the playing and the sound of each kick.. or if a variation
in mic's affecting the sound is ok too.
Sponsored Links
The simple answer is duplication, get another D112.
However, something such as a Beta 52 or an AT AE2500 would be fine, too. The main thing you need to
be concerned with, obviously, is capturing the sound properly to tape/HD.
It really becomes a matter of choice, taste and what you're striving for. A 52 shouldn't be so
different as to be "bad" for the session. And variety is a good thing, too.
--fletch
Reply to Anonymous
If the drummer uses the same heads and tunes them the same and they are the
same size bass drum etc you will probably want identical mics. If the drums
are different though it' not necessarily a requirement to use identical
mics.
You may want to get another mic for bass that is a lot different than your
current one and then compare them for a while, then get a second of the one
that is most versatile so you have a pair.
I highly recommend the Audio Technica ATM25 for internal bass drum mic'ing.
( somewhere from 3 to 6 inches away from the head usually works for me )
John L Rice
Drummer@ImJohn.com
<docgorpon@aol.com> wrote in message
news:1113240390.845956.251010@g14g2000cwa.googlegroups.com...
Reply to Anonymous
In article <1113240390.845956.251010@g14g2000cwa.googlegroups.com>,
> is desirable..
Who decided that? What about (arguably more common currently) double
pedal players? Must they use two different style beaters? It depends on
the drummer, the song, and the intended vision. I'd usually choose the
same mic for the typical identical drum double bass kit if possible, but
it's been a while since I've personally seen two kick drums in a studio.
Funny, when I saw the topic, I expected a question about a double bass,
(an upright acoustic bass), not two bass drums.
Jay Frigoletto
Mastersuite
www.promastering.com
Reply to Anonymous
"Jay-atldigi" <atldigi@aol.com> wrote in message news:atldigi-B4ECC9.00092612042005@news.verizon.net...
> > is desirable..
If it were rock and roll, I'd probably prefer to deal with the comfort of using
a couple of mics that were the same... I'd expect the tuning of the drums
to be the sound the drummer wanted and the difference you speak of.
With a little drumming in my past, I venture that the most likely cause of
variations in sound would be the technique & playing style of the drummer.
Knowing that a couple of similar mics were used starting out, one could at
least be certain of getting a balanced view of what's different about the two
sounds.
Double pedals with single bass drums are just about all I've seen for the
past several years... and yet there's almost *invariably* a tonal difference
between notes struck from each of the pedals.
> Jay Frigoletto
> Mastersuite
PS: I've been looking for what one or two different microphones people
would favor on the upright acoustic double bass. <g>
David Morgan (MAMS)
http://www.m-a-m-s DOT com
Morgan Audio Media Service
Dallas, Texas (214) 662-9901
_______________________________________
http://www.artisan-recordingstudio.com
Reply to Anonymous
I guess I forgot to mention that I'm dealing mostly with metal or
hardcore type bands. My idea that kick drums shouldn't sound the same
is, I guess, from hearing such bands as Slayer in which you can hear
the two different kicks going back and forth (almost sounds like
they're different sizes or tuned differently sometimes). That's how I
like it to sound, as opposed to some other people that have the exact
same sound for each kick, almost sounding like a trigger or something..
so that the double bass ends up being this continuous, annoying,
headache inducing sound throughout the song.
Reply to Anonymous
In article <1113320165.189809.229380@f14g2000cwb.googlegroups.com>,
My issue is that you can basically get only one kick drum sound out
of the D112. With something like an SM-7 or an RE-20 or even a 421,
you can do a lot of heavy equalization to get different drum sounds,
but the D112 is already so peaky there isn't much you can do with it.
Either you like the sound you get from it, or you use another mike, you
can't do much else.
With an RE-20 and a parametric you can make it sound a lot like a D112.
With a D112, you can only make it sound like a D112.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
"Scott Dorsey" <kludge@panix.com> wrote in message
news:d3gqt6$sr7$1@panix2.panix.com...
> can't do much else.
> --scott
And while I don't own any of the mics Scott mentioned, ( definitely someday
though ), I agree with wanting to have a versatile mic and the ATM25 has
worked out very similarly for me as it seems to be easy to dial in a lot of
different sounds with EQ (click, boom and punch are all there if you need
them )
John L Rice
Drummer@ImJohn.com
Reply to Anonymous
If you WANT both drums to sound different then, sure, go with different
mics, but keep in the mind that the Beta52 and the D112 are very
different beasts. The 52 is very deep sounding with a crisper high end
than the D112. The D112 will deliver much more attack and smack of the
bass drum, but not quite as much in thumpy low end. This may be the
effect that you want (i.e. one bass drum as a nice low main kick and the
other as accent).
The 52 is my main kick mic and i love it. It takes a little time to
figure out what it likes in terms of positioning, but once you're
familiar with it you'll love it.
Roach
Reply to Anonymous
There are 1145 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
