Tom's Hardware > Forum > Audio > Pro Audio > Mixing down to Audacity - any sound quality loss?
Forum Audio : Pro Audio - Mixing down to Audacity - any sound quality loss?
Archived from groups: rec.audio.pro (More info?)
I'm going to be mixing down from 8 track reel to reel to my PC. I'm
going through Mytek A/D converters through a RME soundcard and will be
recording at 24 bit/96khz.
After mixing down I'll hand-off the 96khz files to a mastering
engineer. I was wondering how the audio recording software I choose
affects the sound, if at all.
Rather than buying an expensive program, I was planning to just use
Audacity for the recording. I won't be applying any processing to the
wav files once they are in my PC. Just saving them and handing off to a
mastering engineer.
Is it a bad idea to use a free wav editing program for this or is
recording wavs the same no matter what program you get? My guess is
that you're paying the money for the effects processing and multi-track
features of things like Pro Tools and Soundforge. Am I correct with
that assumption?
Dennis
Sponsored Links
> mastering engineer.
> that assumption?
Yeah.
If your sound card is bit accurate, then it is bit accurate(?)! If
Audacity is stable and your hardware is stable, it doesn't matter an iota
what program you use to transfer the bits to a hard drive. I've seen cheap
programs like audacity work better on cheap systems than more expensive
programs, specifically Cool Edit on more expensive systems. This always
puzzled me as I've never had any recording problems with Cool Edit ay home,
but I have heard of several cases where there was a problem. In one of
those cases, there were no problems when recording with Sound Forge instead.
If your hardware is happy, you can probably use any old software to record,
but... don't take it for granted until Audacity has earned your trust.
Julian
Reply to Anonymous
In article <1113282596.294546.73530@f14g2000cwb.googlegroups.com> stuben_baines@yahoo.com writes:
Very little. What affects the sound most is the A/D converter and you
have that very well covered. Audacity will work just fine for this
application.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
be
The software itself does not effect the sound unless there's
some problem.
(OPINION: 96k may be overkill for this purpose)
a
> mastering engineer.
What ?, no compression, limiting, or effects ? ; -]
If you're not going to use any digial processing,
why not just mix in the analog domain and record
2 track into the software ?
It's a great idea, but ...
Audacity does not use any .wav file type as a native format.
It uses a proprietary file type *.au, wav files must be imported
or exported to/from the .au filetype. If you want to output .wav
files they can be exported but it is more time/steps/drivespace.
This is one of the reasons I have stopped using Audacity
for the time being, but I am strongly in favor of the concept
of open source. I'll try it again after a few more version updates.
multi-track
> that assumption?
Pro tools is multitrack, as is Audacity.
Sound Forge is 2 track only.
Maybe I'm not clear on what you are doing.
Do you need all 8 tracks seperate in the software
or can you use a 2 track stereo file ?
Either way Audacity will do what you need, it will
just take a few more steps than the same operation
in (for example) Forge.
I suggest you download Audacity and give it a try
anyway, the price is right and I think you can get
what you need from it.
> Dennis
Good luck
rd
Reply to Anonymous
Thanks for all the great responses.
Sorry for not being clear on this, but I will be mixing in the analog
domain. I am using the PC just to capture the 2 track mixes. All
effects and fades will be done from the board.
Yeah, all I'll need is a 2 track recording software. I wasn't planning
on using any of Audacity's multitrack abilities, just record a stereo
file coming out of my analog mixer. If there are other free or low-cost
2 track recording apps, I'm open to suggestions.
Dennis
Reply to Anonymous
[snip]
The software shouldn't make no difference at all to the sound quality.
If you are going analog into the PC, the critical factor is the quality
of the PC sound card. Sound cards differ in susceptibility to noise and
quality of A-D conversion. I'd guess your RME should be OK, though at 24
bits I'd expect several of the lower order bits to be occupied with
fathfully reproducing tape noise :-)
After A-D conversion it's all just numbers and files and there's no loss
of information. If you were doing *processing* (e.g. compression, EQ) on
the mix with Audacity/a.n.other then you might need to be discussing
quality in connection with the software.
Having said that, latency and overruns are a possible problem with any
PC recording setup, but that has a lot to do with the operating system,
device drivers, what other tasks are running etc.
Anahata
Reply to Anonymous
There are 1277 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
