Login problem
Hello,
I cant log into Windows 7.Says password is wrong but i know its correct.I dont have a password reset disk.
I dont have a backup either.I have files that i want to access.
From what i can gather i think i pretty much have to re-install Windows ?
Is it most likely a virus caused problem ?
1 answer Last reply
More about login problem
  1. Make sure it's not an upper case/lower case mistake and that your user name is correct alt+ctrl+del. Otherwise yes, re-install windows is the only way. It's either not your PC or someone hacked your PC, physically or remotely.
Security Windows 7 Login
