Tom's Hardware > Forum > Mobility Networks > Sprint PCS > SANYO PM 8200...Speed dial?
Forum Mobility Networks : Sprint PCS - SANYO PM 8200...Speed dial?
Archived from groups: alt.cellular.sprintpcs (More info?)
OK.so i have #s on my speed dial up to #9.But i'd like to put more,like
on 10,11,12 & so forth.Is there sumthing i'm missing here? the
instruction book isnt very helpful.I thought this phone held more speed
dial? or is 9 the total?
Sponsored Links
I think the assumption (by the engineer of the phone) is that with
often called people, the call history is used to dial the number, etc.
Reply to Alan
My wife's Sanyo 8100 is as you described. It only has 8 or 9
single-digit speedials (2-9 or 2-0). This is diffrent from most
Samsungs in which the phonebook slot number = the speedial number (1, 2
or 3 digits).
Though the Sanyo system has only 8 or 9 speedials (which is all that
many people can remember anyway), you can assign speedials to more than
one number from a phonebook slot. For example, you can have your
spouse's work and cell numbers in one phonebook entry and each can be
assigned to a single-digit speedial. With a Samsung, you have to make
separate phonebook slots for the work and cell numbers so that they can
be separate speedials.
Frank Harris in San Francisco with an A680
Reply to Anonymous
In article <MAZEe.218$iM7.114@newssvr21.news.prodigy.com>,
>or 3 digits).
Actually with 8200 you don't need to assign different numbers of the
same entry to different speeddials -- you can access all numbers through
one speeddial. Prese *and release* the speeddial number, and as your
programmed entry is displayed, you can use left and right arrows to
cycle through all the different numbers in that entry.
So if you program mobile numbers of your most common callees to
speeddials, pressing <number> <right arrow> TALK will call their home
numbers.
What I don't understand is why they don't have speeddials on buttons
0 and 1 (there are plenty of other buttons they could've used for
voicemail instead of 1, and 0 is practically unused).
Oleg
oleg | The "From" address is temporary.
@ | <---- If expired, use this one.
sashos |
.com | "Can you count to 1023 on your fingers?"
Reply to Anonymous
"Oleg O." <un-jan05@sashos.com> wrote in message
news:dclps4$c8c$1@reader2.panix.com...
> >or 3 digits).
> numbers.
1 is set to call your voice mail. O is used to call the operator ...
Bob
Reply to Anonymous
In article <sCuHe.12257$oZ.11272@newsread2.news.atl.earthlink.net>,
I know, but those are unfortunate choices. As I mentioned, there
are plenty of buttons that could've been used to call voicemail when
held (e.g. MENU/OK, TALK, BACK, *, #), and Operator could've been
preprogrammed as a regular speeddial, changeable if desired.
sashos |
Reply to Anonymous
There are 1345 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
