Tom's Hardware > Forum > General Networking > General Gateways, Routers and Firewalls > MN-700 Kicking Off Wireless Connection
Forum General Networking : General Gateways, Routers and Firewalls - MN-700 Kicking Off Wireless Connection
Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
I just bought the MN-700, the four port switch works fine
on my desktop. But the wireless doesn't work well. I will
get on the internet and 5 minutes later it loses the
connection, i reestablish it and then i lose it again. I
heard of other people having the same problem. Does anyone
know how to fix this.
Sponsored Links
Hi,
Try disabling the 802.1x authentication on your wireless network card
properties.
If 802.1x authentication is enabled on your wireless network card and if
your access point doesn't support this authentication the connection will be
disconnected after a few minutes.
To disable 802.1x authenication over your wireless network card...
1.. Click Start, point to Connect To, click Show all connections, and then
double-click your wireless network adapter.
2.. On the General tab, click Properties.
3.. Click the Wireless Networks tab.
4.. Under Preferred Networks, click your home network, and then click
Properties.
5.. Click Data encryption (WEP enabled).
6.. Click the Association tab, and then click to clear the Network
Authentication (Shared mode) check box and the The key is provided for me
automatically check box, if they are selected.
7.. Click the Authentication tab, and then click to clear the Enable IEEE
802.1x authentication for this network check box, if it is selected.
8.. Click OK two times to accept the changes.
Gary Tsang
Microsoft MVP - Windows XP Shell/User
http://www.microsoft.com/mvp
"Tristan" <anonymous@discussions.microsoft.com> wrote in message
news:15f8901c4472c$757fcf20$a101280a@phx.gbl...
Reply to Anonymous
The 802.1x authentication wasn't enable to begin with so
thats not it. Thanks anway. Do you have any other ideas
Tristan
>-----Original Message-----
>Hi,
network card
>properties.
network card and if
connection will be
card...
and then click
>Properties.
the Network
provided for me
selected.
>Gary Tsang
message
Reply to Anonymous
Hi,
Do you have any other 2.4GHz wireless devices such as the cordless phones,
microwaves or 2.4GHz video receiver/transceivers.
Try changing the wireless channels on the MN-700 and see if that fixes the
problem.
Gary Tsang
news:15eab01c44738$e43de9e0$a501280a@phx.gbl...
> Tristan
>>Hi,
> network card
>>properties.
> network card and if
> connection will be
> card...
> and then click
>>Properties.
> the Network
> provided for me
> selected.
>>Gary Tsang
> message
Reply to Anonymous
- 0 +
I don't have any wireless phones nearby or a microwave, I
tried chnaging the channel, and I got the same result
Tristan
>Hi,
cordless phones,
if that fixes the
>problem.
>Gary Tsang
>> Tristan
>>>Hi,
>> network card
>>>properties.
>> network card and if
>> connection will be
>> card...
>> and then click
>>>Properties.
>> the Network
>> provided for me
>> selected.
>>>Gary Tsang
>> message
Reply to Tristan
Tristan,
I had the same problem and have turned off QOS in the
TCP/IP configuration page for the the NIC.
Have been up for over an hour without a kick off!!
Regards
Ivan
>Tristan
>>Hi,
the
>cordless phones,
>if that fixes the
>>problem.
>>Gary Tsang
so
ideas
>>> Tristan
>>>>Hi,
wireless
>>> network card
>>>>properties.
>>> network card and if
the
>>> connection will be
network
>>> card...
network,
>>> and then click
>>>>Properties.
clear
>>> the Network
key is
>>> provided for me
it is
>>> selected.
>>>>Gary Tsang
in
>>> message
fine
I will
again. I
anyone
Reply to Anonymous
- 0 +
I disabled the QoS packet scheduler and a few minutes later
i got kicked off again
Tristan
>Tristan,
>Regards
>Ivan
>>Tristan
>>>Hi,
>the
>>cordless phones,
>>if that fixes the
>>>problem.
>>>Gary Tsang
>so
>ideas
>>>> Tristan
>>>>>Hi,
>wireless
>>>> network card
>>>>>properties.
>>>> network card and if
>the
>>>> connection will be
>network
>>>> card...
>network,
>>>> and then click
>>>>>Properties.
>clear
>>>> the Network
>key is
>>>> provided for me
>it is
>>>> selected.
>>>>>Gary Tsang
>in
>>>> message
>fine
>I will
>again. I
>anyone
Reply to Tristan
Damn!! ;-)
Have you tried stopping the Wireless Zero Configuration
service??
Ivan
later
>Tristan
>>Tristan,
>>Regards
>>Ivan
microwave, I
>>>Tristan
>>>>Hi,
>>the
>>>cordless phones,
see
>>>if that fixes the
>>>>problem.
>>>>Gary Tsang
message
with
>>so
>>ideas
>>>>> Tristan
>>>>>>Hi,
>>wireless
>>>>> network card
>>>>>>properties.
>>>>> network card and if
authentication
>>the
>>>>> connection will be
>>network
>>>>> card...
all
>>network,
>>>>> and then click
>>>>>>Properties.
>>clear
>>>>> the Network
>>key is
>>>>> provided for me
to
if
>>it is
>>>>> selected.
>>>>>>Gary Tsang
wrote
>>in
>>>>> message
works
>>fine
well.
>>I will
the
>>again. I
Does
>>anyone
Reply to Anonymous
- 0 +
No how would i do that
Tristan
>Damn!! ;-)
>service??
>Ivan
>later
>>Tristan
>>>Tristan,
>>>Regards
>>>Ivan
>microwave, I
>>>>Tristan
>>>>>Hi,
>>>the
>>>>cordless phones,
>see
>>>>if that fixes the
>>>>>problem.
>>>>>Gary Tsang
>message
>with
>>>so
>>>ideas
>>>>>> Tristan
>>>>>>>Hi,
>>>wireless
>>>>>> network card
>>>>>>>properties.
>>>>>> network card and if
>authentication
>>>the
>>>>>> connection will be
>>>network
>>>>>> card...
>all
>>>network,
>>>>>> and then click
>>>>>>>Properties.
>>>clear
>>>>>> the Network
>>>key is
>>>>>> provided for me
>to
>if
>>>it is
>>>>>> selected.
>>>>>>>Gary Tsang
>wrote
>>>in
>>>>>> message
>works
>>>fine
>well.
>>>I will
>the
>>>again. I
>Does
>>>anyone
Reply to Tristan
Before stopping any services, are you on Windows XP, and, if so, are you
completely updated from Windows Update?
Chris H.
Microsoft Windows MVP
Tablet Creations - http://nicecreations.us/
Associate Expert
Expert Zone - www.microsoft.com/windowsxp/expertzone
news:161bd01c44758$3702c8c0$a101280a@phx.gbl...
> Tristan
>>Damn!! ;-)
>>service??
>>Ivan
>>later
>>>Tristan
>>>>Tristan,
>>>>Regards
>>>>Ivan
>>microwave, I
>>>>>Tristan
>>>>>>Hi,
>>>>the
>>>>>cordless phones,
>>see
>>>>>if that fixes the
>>>>>>problem.
>>>>>>Gary Tsang
>>message
>>with
>>>>so
>>>>ideas
>>>>>>> Tristan
>>>>>>>>Hi,
>>>>wireless
>>>>>>> network card
>>>>>>>>properties.
>>>>>>> network card and if
>>authentication
>>>>the
>>>>>>> connection will be
>>>>network
>>>>>>> card...
>>all
>>>>network,
>>>>>>> and then click
>>>>>>>>Properties.
>>>>clear
>>>>>>> the Network
>>>>key is
>>>>>>> provided for me
>>to
>>if
>>>>it is
>>>>>>> selected.
>>>>>>>>Gary Tsang
>>wrote
>>>>in
>>>>>>> message
>>works
>>>>fine
>>well.
>>>>I will
>>the
>>>>again. I
>>Does
>>>>anyone
Reply to Anonymous
Why would you do that?
Jason Tsang - Microsoft MVP
Find out about the MS MVP Program -
http://mvp.support.microsoft.com/default.aspx
"Ivan Sanders" <anonymous@discussions.microsoft.com> wrote in message
news:1616a01c44756$1eed1530$a001280a@phx.gbl...
> Damn!! ;-)
> service??
> Ivan
> later
> >Tristan
> >>Tristan,
> >>Regards
> >>Ivan
> microwave, I
> >>>Tristan
> >>>>Hi,
> >>the
> >>>cordless phones,
> see
> >>>if that fixes the
> >>>>problem.
> >>>>Gary Tsang
> message
> with
> >>so
> >>ideas
> >>>>> Tristan
> >>>>>>Hi,
> >>wireless
> >>>>> network card
> >>>>>>properties.
> >>>>> network card and if
> authentication
> >>the
> >>>>> connection will be
> >>network
> >>>>> card...
> all
> >>network,
> >>>>> and then click
> >>>>>>Properties.
> >>clear
> >>>>> the Network
> >>key is
> >>>>> provided for me
> to
> if
> >>it is
> >>>>> selected.
> >>>>>>Gary Tsang
> wrote
> >>in
> >>>>> message
> works
> >>fine
> well.
> >>I will
> the
> >>again. I
> Does
> >>anyone
Reply to Anonymous
- 0 +
I am in Windows XP, I just did a Windows Update and I get
the same result
Tristan
if so, are you
>Chris H.
>Associate Expert
message
>> Tristan
>>>Damn!! ;-)
>>>service??
>>>Ivan
>>>later
>>>>Tristan
>>>>>Tristan,
>>>>>Regards
>>>>>Ivan
>>>microwave, I
>>>>>>Tristan
>>>>>>>Hi,
>>>>>the
>>>>>>cordless phones,
>>>see
>>>>>>if that fixes the
>>>>>>>problem.
>>>>>>>Gary Tsang
>>>message
>>>with
>>>>>so
>>>>>ideas
>>>>>>>> Tristan
>>>>>>>>>Hi,
>>>>>wireless
>>>>>>>> network card
>>>>>>>>>properties.
>>>>>>>> network card and if
>>>authentication
>>>>>the
>>>>>>>> connection will be
>>>>>network
>>>>>>>> card...
>>>all
>>>>>network,
>>>>>>>> and then click
>>>>>>>>>Properties.
>>>>>clear
>>>>>>>> the Network
>>>>>key is
>>>>>>>> provided for me
>>>to
>>>if
>>>>>it is
>>>>>>>> selected.
>>>>>>>>>Gary Tsang
>>>wrote
>>>>>in
>>>>>>>> message
>>>works
>>>>>fine
>>>well.
>>>>>I will
>>>the
>>>>>again. I
>>>Does
>>>>>anyone
Reply to Tristan
Then I would suggest you try a simple, basic function. Unplug the power
from the base station for about 20 minutes. Turn the computer off and talk
a little walk outside. Come back in and unplug the power from your
broadband modem for about two minutes. Then plug that in, let it go through
connecting with your ISP. After all the lights are green, plug the power
back in to the base station. When that has properly negotiated the
connection with the mode, go ahead and start your computer.
If that doesn't work, call the product support number in the User's Guide.
Chris H.
Associate Expert
news:1628901c44770$8be5a9d0$a101280a@phx.gbl...
> the same result
> Tristan
> if so, are you
>>Chris H.
>>Associate Expert
> message
>>> Tristan
>>>>Damn!! ;-)
>>>>service??
>>>>Ivan
>>>>later
>>>>>Tristan
>>>>>>Tristan,
>>>>>>Regards
>>>>>>Ivan
>>>>microwave, I
>>>>>>>Tristan
>>>>>>>>Hi,
>>>>>>the
>>>>>>>cordless phones,
>>>>see
>>>>>>>if that fixes the
>>>>>>>>problem.
>>>>>>>>Gary Tsang
>>>>message
>>>>with
>>>>>>so
>>>>>>ideas
>>>>>>>>> Tristan
>>>>>>>>>>Hi,
>>>>>>wireless
>>>>>>>>> network card
>>>>>>>>>>properties.
>>>>>>>>> network card and if
>>>>authentication
>>>>>>the
>>>>>>>>> connection will be
>>>>>>network
>>>>>>>>> card...
>>>>all
>>>>>>network,
>>>>>>>>> and then click
>>>>>>>>>>Properties.
>>>>>>clear
>>>>>>>>> the Network
>>>>>>key is
>>>>>>>>> provided for me
>>>>to
>>>>if
>>>>>>it is
>>>>>>>>> selected.
>>>>>>>>>>Gary Tsang
>>>>wrote
>>>>>>in
>>>>>>>>> message
>>>>works
>>>>>>fine
>>>>well.
>>>>>>I will
>>>>the
>>>>>>again. I
>>>>Does
>>>>>>anyone
Reply to Anonymous
Run your anti-virus (and /or any ad-virus) program, and
delete the trojan, trackers, and hi-jackers.
Reply to micronerdo
- 0 +
I'm sure you've done this, but make sure any other NICs
are disabled.
I'm still having some issues with mine. To get mine to
reconnect I have to stop the card pull it out and reinsert
it to get it to connect again.
Reply to Rob
There are 1217 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
