Quick Summary: Split drive into 3 partitions, 1 partition will not format. Also, I'm getting an "Image simulation SCSI CdRom Device." listed as a CD-Rom under disk management and my computer. The thing is, it's comming from the HD. Please help if you can...
I just received a Western Digital 180GB (special edition) drive as a replacement for a defective unit that I had. I noticed that this replacement drive has been refurbished. When I first intalled it, it was recognized in BIOS, but disk management and windowsXP did not detect it. The only thing that was detected was an "Image Simulation SCSI CdRom Device" (note: HD is connected through an Ultra IDE card). I thought that some of the previous owner's data may still be on the drive so I used Datalifeguard utilities to erase the drive (write 0's). That seemed to work. I was then able to install the drive using datalifeguard (before erasing I received erros when trying to install). I split the 180GB drive into three partitions (NTFS). The first two, each of 56.27GB seem to work fine. However, the third partition of 55.10GB is not responding. Under Disk Management it's listed without a file system and with 100% free space. I tried doing a full format and a quick format, each resulted in the message "the format did not complete successfully" Also, which I find odd but important, I still have a CD-ROM device listed that shouldn't be there. It's coming from the Hard drive, but I don't know why it's being seen as a CD-Rom. It's being called an "Image simulation SCSI CdRom Device." Please respond as soon as you can, your help is very appreciated. Thanks!
Mobo: Epox 8K7A+
CPU: AMD Athlox XP2200+
OS: Windows XP pro SP1
HD: WD 80GB
HD: WD 180GB SE
RAM: 2x512MB DDR 2100
Mobo: Epox 8K7A+
HD: WD 80GB
HD: WD 180GB SE
