I have been trying to install XP Pro on my new computer, but when ever it gets done, it says there are errors and windows needs to shut down [its a blue screen] it lists the files that have erors
then when i reboot it says something about ntfs.sys and thats it, ive tryed reformatting and reinstalling, any ideas?
its on a fresh ntfs partition..
i was unable to install win98 with the same type of crashes, i have only been able to install NT on it
1.7 p4
60gig WD
<font color=green>I can draw tyte give me the damn crayon!</font color=green>
Sponsored Links
and what might these errors be ? "something about ntfs.sys" isnt really a lot to go on, but it sounds like the ntfs drivers which are loaded during the initial install are having probs, how are you installing xp ? from a 98 bot disk by anychance?
If they squeeze olives to get olive oil, how do they get baby oil?
Reply to CALV
Is your memory overclocked? I'm asking because I just read this thread about file corruption, and a possible solution.
<A HREF="http://"File Corruption and a solution"[/url" target="_new">http://forumz.tomshardware.com/hardware/modules.php?name=Forums&file=viewtopic&p=39901#39901</A>
Perhaps you can check that. Other than that, I'm not sure what else to recommend. Hopefully someone else knows.
<font color=red><A HREF="http://www.btvillarin.com" target="_new">btvillarin.com</A> - My Windows XP-based Website</font color=red>
Reply to btvillarin
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > XP Instalation Problem
There are 1181 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
