Okay, everything was working fine with XP, and then sometihng gets f**ed up and I need to reinstall.
Reinstall goes fine, but now I cant turn the computer off. Turn Off makes it display the annoying Windoze 95-esque "It is now safe to turn off your computer". Pressing the power button does nothing. Pressing the restart button works. Unplugging the damn thing works. In all other instances, the power button works just fine.
I have disabled Hibernate from the "Power" control panel, but the problem still occurs. This was not happening before the reinstall.
Can anyone help me out here? This is really annoying....
"If you teach a child to read, then he or her will be able to pass a literacy test" - George W.
