Tom's Hardware > Forum > Audio > Pro Audio > problem with live "vocals"
Forum Audio : Pro Audio - problem with live "vocals"
Archived from groups: rec.audio.pro (More info?)
i'm having some trouble amplifying a rather quiet voice on a loud
stage. it's a song wherein guitars rage hard and one guy kinda talks
neurotic. now i'd like to have this talking in the mix so that it's
"almost not understandable, but hearable", problem is that i have to
pull up the gain so hard so that i absorb the whole stagesound into
that one mic (mostly a 58) with feedback as a consequence? what could
help?
thanxx
Sponsored Links
"Bert Aerts" <bert_aerts@advalvas.be> wrote in message news:6894667a.0504230243.5ca71cab@posting.google.com...
> help?
> thanxx
There's really only one answer unless you buy a monstrous PA and
dedicate it to vocals... turn everyone else down.
I hate it when I could get a good recording of the whole band through
just the singer's mic. :-(
DM
Reply to Anonymous
>help?
1. A tighter mike
2. Mike placement so it's away from the monitors and getting as little feed
as possible from the mains.
The SM-58 has a very wide pattern and not much top end at all, which makes
it a real nightmare in this kind of situation. An SM-57 might be a little
better if you can't find anything in the kit that has a seriously tight
pattern.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
On 4/23/05 6:43 AM, in article
6894667a.0504230243.5ca71cab@posting.google.com, "Bert Aerts"
> help?
> thanxx
Everyboy
Else
Has
To Turn Down
Actually if you can still get the old CROWN handheld differoid mic you'll
nail this.
The singer must learn to use NO mic technique since as soon as you back off
1/2" you VANISH. Once watched a Clair Brothers setup crew play with one of
these with a guy shoving his face right into one of their big wedges set on
STUN blowing his hair back when he said "CHECK"... but NO feedback!
Reply to Anonymous
On 4/23/05 7:07 AM, in article T%pae.481$Nc.117@trnddc08, "David Morgan
>> help?
>> thanxx
It has on several occasions saved me from putting up OH's on a drum kit...
Reply to Anonymous
could
> help?
My associate and I recently did some informal comparisons of several
of the vocal mics we had on hand. I knew that the SM58 was not the
best vocal mic in the world, but I was amazed how badly it came off in
comparison with the other admittedly low-cost mediocre mics we had on
hand.
I'm no doubt any number of decades behind the tip of the technological
spear by reporting that the hypercardiods we tried (Audix OM-3, OM-5,
and OM-6) had very strong advantages in terms of picking up the
vocalist well, giving a natural sound, while avoiding much of the
sound field around him. I was even more surprised that the plain
old-tech relatively cheap condenser cardioid we tried (CAD 95) showed
a lesser, but still strong advantage in the same performance areas.
Just because the SM58 is cheap, readily available and widely accepted,
doesn't mean that its particularly good.
Reply to Anonymous
In article <6894667a.0504230243.5ca71cab@posting.google.com> bert_aerts@advalvas.be writes:
> stage.
Yeah. You and everybody else. <g>
> help?
The thing that would help most is better technique on the part of the
vocalist. Get him to practice doing his mumbles with his lips touching
the mic, then learn about the directivity pattern of the mic and find
a place to stand where the null in the pattern is pointing toward the
loudest sound source. Getting close to the mic will reduce the
feedback problem by allowing you to use less gain. And less gain means
less leakage from the rest of the stage.
It's obviously a drama trick. It's OK if he crouches over and turns
his back to the audience during this passage. However, if he goes back
to singing normally in the same song, you'll really need someone to
ride gain on the mic. A compressor or other "automatic" tool won't
work and will only enhance your feedback.
I'm really Mike Rivers - (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
In ear monitors would be ideal, certainly for keeping the stage volume sane
Rick Hollett
> help?
> thanxx
Reply to Anonymous
"SSJVCmag" <ten@nozirev.gamnocssj.com> wrote in message news:BE8FC814.6438%ten@nozirev.gamnocssj.com...
> >> help?
> >> thanxx
Unless it's in the rider of a 'major', I never put up overheads on a stage
smaller than 30w by 20d in a venue that seats less than 500.... any more
than one or two vocals and we've got more 'overheads' than we'll ever
need. (I also pray for non-singing drummers). In many cases that have
the kind of volume we're obviously talking about here, if there are three
vocals across the front, I don't need anything in the PA but kick, toms,
and those vocal mics unless I'm recording. I try to avoid shows like that
these days.
DM
Reply to Anonymous
> these days.
> DM
Sounds like SM58's with compressors on them. Whenever there's drums in
small venues my limit for 58's is one, and the person insisting on using it
better have a damn good reason. And I don't hesitate to wash and dry mic
caps if it's a matter of hygene, anything to get tighter pattern mics going.
Then I put a compressor/limiter on a subgroup so I can switch the mic(s)
being compressed without repatching, fed out the subgroup insert (to prevent
it from going to main mix) and back through a full strip for post auxes.
Rarely will I have more than one vocal mic compressed under those
circumstances, and virtually never three.
And a mic I'm starting to like for overheads is the Audix F15. It's a cheap
and frankly rather trashy-sounding mic in the studio, but it has a strong
top octave that finds its way past the harsh 3-6kHz of cymbals at close
range, which is the only reason I put overheads up in small rooms. The F15
worked a lot better for that than many much silkier (and expensive) mics for
the blues/rock bands I've tried them with, though it's probably a little
rough for mellower acts.
Reply to Anonymous
Try a used AKG c535 (I have purchased on ebay for $125). The C535 is a
condenser with a very tight pattern.
John
Reply to Anonymous
On 4/24/05 10:45 AM, in article
1114353941.971175.108170@l41g2000cwc.googlegroups.com, "jmuirman1@aol.com"
OK... I keep hearing this and have NO clue where it came from.
Known and used these for AGES and that's the OPPOSITE of why I grab one...
The 535 is a top-drawer mic designed in the early-80's as a dedicated vocal
mic of Mercedes calibre and succeeds marvelously in reflecting it's heritage
to the 451/CK1 series of mics. As such (and the singular reason I have and
love them) is that it's is a CLASSIC cardioid pattern across most of its
range and beyond that KEEPS a good spectral match over most of its front
pattern. It's all of 5 dB down or so at 90deg off-axis (except at EXTREME hi
end where it narrows), hardly MY idea of a 'tight' pattern, and BECAUSE of
all that it:
A- Sounds wonderful even with singers with poor technique
B- helps in stage sound, by dint of its even coverage, by not causing odd
changing feedback points when it's moved or the performer moves in front of
it, and whatever it DOES pick up in the free field doesn't sound 'odd'.
C- doubles as a VERY desirable Anything Mic.
When these things plummeted from the $500+ range to the $200+ range several
years back I thought I'd died and gone to heaven. They should be flying out
store doors by the handful....
But 'tight pattern'?
Reply to Anonymous
I like you love these mics - I have 4 535s and always use one for
vocals when I sing out - sometimes I'll 535 my guitar along with a
Pendulum DI - have had lots of compliments on that set-up. My opinion
is based on my experience rather than science - so you may be
technically correct. For being a cardioid though, it seems tight to me.
I can't move off center of the 535 anywhere near as much as a 58 and
still sound good. Also, I just searched this group, and found that many
of the pros refer to the 535 in terms of a tight pattern. YMMV
John
Reply to Anonymous
SSJVCmag <ten@nozirev.gamnocssj.com> wrote about the C535:
Well, compared with an SM-58, it's got a very tight pattern. Compared with
a Sennheiser 441 or a Neumann KMS105, it has a very wide pattern.
The EV 468 is another real sleeper... it has a very tight cardioid pattern
and a reasonably flat midrange with no presence peak, for about a hundred
bucks. It's a poor man's 441.
--scott
Reply to Anonymous
Further Reading...
http://www.soundonsound.com/sos/se [...] ection.htm
Reply to Anonymous
That's the attitude that gives SR people a bad name. You want me to come
up on stage and tell you to change basses, change amps? Think about it.
If someone wants to sing into a '58, my job is to make that work as well
as I can. If it doesn't work well my job is to try to explain why. If
the singer still wants that '58, I go with it.
ha
Reply to Anonymous
In article <d4gi06$t19$1@panix2.panix.com> kludge@panix.com writes:
But it just doesn't LOOK like a vocal mic. You know how important that
is.
Reply to Anonymous
On 4/24/05 7:21 PM, in article znr1114367321k@trad, "Mike Rivers"
> is.
Man, does the BLUE ball mic in the BLUE spiderweb look like a vocal mic or
what!
Reply to Anonymous
In article <BE91AC4B.65B4%ten@nozirev.gamnocssj.com> ten@nozirev.gamnocssj.com writes:
> what!
Perhaps from far enough away so that you can't tell that it looks like
a plastic Wiffle Ball.
Reply to Anonymous
"Joe Sensor" <crabcakes@emagic.net> wrote in message ...
> w.t.f? You seem to be making the most noise and it has nothing to do
> with you.
Didn't you read the subject? It's a problem with vocals.
Reply to Anonymous
No no no... That's hypocrite, not hypercardioid. ;)
Reply to Anonymous
"hank alrich" <walkinay@thegrid.net> wrote in message
news:1gviqvh.g0ob5m111cjxlN%walkinay@thegrid.net...
it
Almost as bad as doing a bad mix because the vocal mics are picking up too
much drums, and then blaming the vocalists for using the wrong mics. It's a
judgment call, and I have my preferences. In my neck of the woods
performers tend to appreciate such efforts.
> You want me to come
If there was a significant problem that could be reasonably solved that way,
why not? I've lent my Ampeg to a guy for a show because his amp was acting
up, didn't hold a gun to his head or anything...
We disagree on the level of influence that we should have on vocal mic
selection. No big deal.
Reply to Anonymous
There are 675 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
