See more for "Recommendation for sound card for recording quality."
Archived from groups: rec.audio.pro,comp.sys.ibm.pc.soundcard.tech (More info?)
Hi,
I have a collection of analogue audio cassettes. I have a Hifi
"Nakamichi cassette deck 2". I want to go through the process of
turning all the cassettes into mp3 files. I have creative I-teague
speakers. I currently have a creative sound blaster gold sound card.
When I plug the I-teague speakers straight into the Nakamichi cassette
deck it gives better sound quality than exsiting mp3s I have playing
from the Sound blaster gold sound card (in comparison it sounds dull
and you're less able to pick out individual instruments).
Please could you recommend me a sound card that will give
significantly better quality than a Soundblaster gold card that might
be able to match the sound quality of the Nakamichi cassette deck? I
obviously don't need any fancy bells and whisles just good sound
quality. Would I be better buying an older card from ebay that is
reknowned for good audio quality that may be a bit cheaper than a
modern card with lots of facilities?
Are you sure that isn't just becuase they're MP3's?
M-Audio Audiophile 2496
On 28 Apr 2005 04:46:56 -0700, wrreisen@yahoo.com (William.R.Reisen)
wrote:
>Hi,
Just about any 16-bit sound card should be much better than
analog tape: Lower noise, better frequency response, no
print-through, etc. The tape will definitely be the limiting
factor here, even with the best of tape decks. (And the
Nakamichi was one of the better ones, as I recall.)
Do a test with your present sound card, and record as
a normal .WAV instead of MP3. Sample at 44100 Hz.
Make sure the recording level is set high enough; you
want it as high as possible, but you must make certain
that it doesn't clip. (Digital clipping is far, FAR worse than
tape saturation!)
I think you will find that this produces excellent results.
Then you can experiment with MP3 bandwidth to see
what level of compression you can tolerate.
Best regards,
Bob Masta
dqatechATdaqartaDOTcom
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
Home of DaqGen, the FREEWARE signal generator
William,
> Please could you recommend me a sound card that will give significantly
better quality than a Soundblaster gold card that might be able to match the
sound quality of the Nakamichi cassette deck? <
I agree with Bob that a $25 SB Live card is head and shoulders above any
cassette deck. Even an MP3 file will beat the pants off any cassette if you
use a reasonably high bit rate.
--Ethan
> tape saturation!)
Bob is right, don't jump to conclusions, but personally I hate sound blaster
cards. I think you'd you yourself a big favor by getting a cheap pro card
like the M Audio, or Echo MIA MIDI or one of the Edirol products. Then do
what Bob says and you should be able to make some very nice MP3's from your
Nakamichi.
Julian
On Thu, 28 Apr 2005 08:12:08 -0700, "Julian Adamaitis"
>Nakamichi.
Best advice so far...
Al
In article <c254b7f4.0504280346.50afae08@posting.google.com> wrreisen@yahoo.com writes:
I think that a modern Soundblaster card won't cause you to lose
anything coming off the cassette. However, MP3s can easily sound not
as good as a good cassette. If you want to maintain the cassette
quality, record PCM format, uncompressed. Then you can experiment with
different encoder programs and different amounts of compression until
you find something that doesn't sound worse than the cassette.
The most important thing you can do when transferring your cassettes
is to adjust the azimuth alignment for each tape, at least check it in
a few places and tweak it for the best compromise if you don't want to
transfer the tapes in sections. The Nakamichi is pretty good, but you
don't know what the tapes were recorded on, and the azimuth (the
perpendicularity of the head relative to the tape) tends to wander
quite a bit with cassettes.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
I don't think so. His Nakamichi cassette deck isn't just any cassette
deck, and the original SoundBlaster Live! cards have terrible resampling.
He's going to want at least a Audigy to do the recording.
Ross Ridge
l/ // Ross Ridge -- The Great HTMU
[oo][oo] rridge@csclub.uwaterloo.ca
-()-/()/ http://www.csclub.uwaterloo.ca/u/rridge/
db //
"William.R.Reisen" wrote:
> Hi,
The better Soundblaster cards are actually not that bad.
Nakamichi cassette decks were also rather good. Why would you want to
trash the potential quality of your cassette recordings by saving them as
mp3s?
I'd recommend ( subject to disk space ) that you try saving them as wav
files. Use uncompressed linear PCM format if that means anything to you.
The coments you make about mp3 quality ring *so* true to me.
/ quote
in comparison it sounds dull and you're less able to pick out individual
instruments
/ endquote.
This is what mp3 does and how it makes the files smaller. It's one of the
'lossy compression' style formats that degrade detail. I've experienced
exactly the same - even when making the comparison on the *car stereo* !
Try again and save as wav files. I bet that'll fix it.
Btw - you won't find any good old sound cards on ebay unless you also tend
to win the lottery regularly.
Graham
> wrote:
> >Hi,
I can assure you that's not true for motherboards with 'integrated sound'
that are often sold advertised as if they had the actual original sound
card installed.
> tape saturation!)
I've listened to mp3 @ 320 kbits/sec and it's still obviously inferior to
the raw uncompressed file. The effect varies with the complxity of the
music btw. A simple guitar / soloist song may sound quite good while
complex passages can be trashed.
I was quite startled after purchasing a certain CD after 'previewing' it
courtesy of an mp3 file to discover that I could hear detail on the CD that
had simply 'vanished' on the mp3 - to the extent of masking low level
backing vocals even !
Graham
Ethan Winer wrote:
> William,
You obviously never owned a Nakamichi ! They are / were the real 'Rolls Royce'
of the breed. Including such features as auto line-up ! You know what a line-up
is ?
About the only cassette deck ever to approach the quality of 1/4" tape. Damn
fine machines. I used a Nakamichi portable as my reference source for setting up
sound rigs many many yrs ago.
Graham
> Hi,
You may find this useful when comparing sound cards.
http://www.pcavtech.com/soundcards/compare/index.htm
It rates a SB 64 Gold as 'acceptable' for many. I'll bet the mp3
compression is at least if not more culpable of trashing the detail.
Graham
On Fri, 29 Apr 2005 02:17:57 +0100, Pooh Bear
> tend
> Graham
I've noticed that there are a few M-Audio Audiophile cards on Ebay at the
moment - around 60 quid new or 30 quid used. It looks like they're about
to replace them with a new model so now is a good time to buy the older
version.
Cheers.
James.
Ross and Graham,
> His Nakamichi cassette deck isn't just any cassette deck, and the original
SoundBlaster Live! cards have terrible resampling. <
> They are / were the real 'Rolls Royce' of the breed. Including such
features as auto line-up ! You know what a line-up is ? <
I've been around a while, and I know all about Nakamichi cassette decks. And
Yes, I know what "line-up" means. :-> )
I agree those are/were great cassette recorders, but that's still not saying
much. Even the best cassette deck is inferior to an SB Live card in any way
you care to measure:
Dynamic range
THD and IM distortion
Frequency response
Wow and flutter
If you still think this is wrong, please list the *specific audio
attributes* where even the best cassette deck could possibly be superior to
an SB Live card. I don't mean "resampling" because that doesn't say anything
specific. And it's expressed better as distortion or noise, or whatever
other standard spec you believe is harmed by "terrible resampling."
BTW, I'm not trying to be argumentative here. I just want to keep things
focused on fact instead of subjective opinion.
--Ethan
So my question is: how much better is the 2-channel recording ability
of this card vs. the Revolution 7.1, or the Audigy 2 ZS? I'm about to get
a new card, and I want surround capabilities, but I'd like to make sure that
the recording quality doesn't suffer (much).
For that matter, how does this compare to my venerable but unsupported
Diamond Monster MX-300?
Thanks,
Colin
> Dynamic range
> Frequency response
> Wow and flutter
You haven't measured any of these values for either piece of equipment.
>specific.
Resampling error is quite specific. The original SoundBlaster Live! cards
did a terrible job of this, and it's quite audible. It's the reason
why the original poster think his MP3's sound so bad, worse than his
tape deck.
You haven't posted any facts. You don't even have any actual, real,
obseverations to form a rational "subjective opinion". You're just
speculating based on assumptions. The fact that I posted however is
both based on reality and it's one that's easily verifiable.
Ross Ridge
db //
What you are experiencing is the slurring of a cheap analogue audio
curcuit on the sound card.
it is designed for fitting into the computer
if you want a better sound you need to
remove all audio curcuits from the computer
exspecially the analogue sections.
the nak has much better audio then most any sound card
it's designed for its musicality.
most sound cards are designed for test specs that confuse
the issue of aesthetics (musicality)
with digital facts.
check out m audio ,
firewire protocol is desirable
dale
In article <427250aa@news.nucleus.com> cbigam@somewhereelse.nucleus.com writes:
You really can't make "how much better" comparisons without defining
what "better" actually means. Any of those cards will work for your
purposes. Make a decision and get to work.
In article <d4u4sg$bgn$1@rumours.uwaterloo.ca> rridge@csclub.uwaterloo.ca writes:
So what? Why can't the guy just use what he has if it works for his
project? I could buy a better car than the one I have, but my present
car can get me to the grocery store just fine. I don't race every
week. In fact, I never race.
>project?
I never said that he couldn't. It's the original poster who doesn't
think what he already has will work for his project.
Ross Ridge
db //
saying
way
and the SBLIVE is SHITE anyway
> Why can't the guy just use what he has if it works for his project?
he does not like what he hears
he wants to improve his setup
dale
"William.R.Reisen" wrote ...
You are assuming your sound card is the cause of the "dull" sound.
You have violated a basic principle of scientific experimentation.
You have changed more than one variable in a single step, so you
can't differentiate between the effect of each of the two (or more)
variables.
Do the experiment of recording to un-compressed WAV files and
playing back. Then at least you can do the "differential diagnosis"
to determine whether it is really the sound card (doubtful IMHO)
or the MP3 compression (much more likely).
SoundBlaster doesn't have a great reputation, but when you casually
mentioned "MP3", you drew suspicion away from the sound card.
You will need to reveal what software you are using to do the MP3
conversion if you want complete responses.
>dale
The OP stated that he did not like what he hears, but
he jumped to the conclusion that it was due to his
sound card. He first needs to rule out the strong
possibility that what he dislikes is the MP3 encoding.
Buying a different sound card won't help that!
Best regards,
Bob Masta
D A Q A R T A
www.daqarta.com
In article <d4uttk$v3j$1@rumours.uwaterloo.ca> rridge@csclub.uwaterloo.ca writes:
> >project?
And I say that it probably will. He's just too lazy or lacking the
confidence in his own judgement to give it a try. If he had, he'd tell
us what he thought was wrong so we could better suggest a path for
improvement. Most people who get into this for the first time don't
even realize that they can adjust the record level (and need to do so).
>project?
So why did you start arguing with me?
>He's just too lazy or lacking the confidence in his own judgement to
>give it a try.
There's no reason to believe that's true.
>If he had, he'd tell us what he thought was wrong so we could better
>suggest a path for improvement.
He's already told us what he thinks is wrong.
Please take the time to read posts in their entirety before responding.
Ross Ridge
db //
Hmm ... about the first I did when testing the Mdiman 2496 Audiophile
was to listen to the change as I changed sampling frequency. I did that
test with a tape that was recorded on the original Philips compact
casette recorder, albeit with a Sennheiser MD211 rather than the ex
works mic.
That would be plain foolish, especially btw. with a soundblaster that
resamples to and from 48 kHz and uses that internally no matter what, a
possibly incomplete rendition of various tales of soundblaster woes. 48
kHz is likely to sound notably better on the small number of converters
I am familiar with and I prefer to use native 32-bit recording format,
and then dither down after relevant repair work.
> tape saturation!)
Your statement contradicts my actual recording experience - up to some 4
dB of clean clipping of Chamber music recorded with high quality
equipment is easily fixable in the digital domain and completely
inaudible even if unfixed. Digital clipping is no better nor no worse
than any other clean clip.
If he wants to use ex works sound cards, then he should perhaps take a
look at the Echo range that Arny Krüger is so fond of.
192 kbit/sec stereo, 96 kbit second mono, fixed bit rate is the format I
selected for my cassette drawer using my preferred encoder.
> Bob Masta
Kind regards
Peter Larsen
* My site is at: http://www.muyiovatki.dk *
> not saying much. Even the best cassette deck is inferior to an SB
> Live card in any way you care to measure:
> Dynamic range
> Frequency response
> Wow and flutter
> superior to an SB Live card.
The sound ... O;-)
> to keep things focused on fact instead of subjective opinion.
I am a member of a tape recordists club here in Copenhagen. The only one
to prefer the sound of his extigy over the M-audio Delta 44 or any other
M-audio card, modded or ex works, is the owner of the extigy.
> --Ethan
I would disagree less on the relevance of a usable sound card if it was
not about someone with a Nak and if I had not made the sampling rate
test with that old recording made on an original portable Philips.
Kind regards
Peter Larsen
On this I agree fully.
> Bob Masta
Kind regards
Peter Larsen
The SoundBlaster Live! always resamples to 48 kHz even when the input
is already 48 KHz. It makes no difference if you use 44.1 kHz or 48
kHz with a original SoundBlaster Live!, you get the same bad resampling.
Ross Ridge
db //
In article <d50il4$jpk$1@rumours.uwaterloo.ca> rridge@csclub.uwaterloo.ca writes:
Would you care to regurgitate it to me? I'm too lazy and too
uninterested to go back to the server and try to look it up? As far as
I recall, he said he didn't care for how it sounds. That doesn't tell
me anything useful.
It's been suggested that the MP3 process may be causing whatever
problem he perceives. We haven't heard back from the original poster
yet that he tried linear recording with his present sound card (after
carefully setting the record level) to see if he still dislikes what
he hears.
No point in arguing among ourselves about what we think he thinks is
wrong when we know he has one big strike (MP3) against him and he's
looking to change his sound card. He may not need to do so.
Or he could just buy a LynxTWO, get the SoundBlaster out of the way,
and then start aking which MP3 encoder will give him results that he
thinks sounds good. But if he takes that approach, he'll never know
whether or not he actually had to spend that $1,000.
"Mike Rivers" <mrivers@d-and-d.com> wrote in message
news:znr1114887334k@trad...
>> responding.
> me anything useful.
The OP's "presenting symptoms" (as they say in the medical biz)...
"I have a collection of analogue audio cassettes. I have a Hifi
and you're less able to pick out individual instruments)."
> he hears.
Precisely.
Hi William,
> I have a Hifi "Nakamichi cassette deck 2".
> I want to go through the process of turning all the
> cassettes into mp3 files. [...]
> that might be able to match the sound quality of the
the secret advice for that task is to pick up
a used Philips DCC tape deck from Ebay or the like.
They are no longer manufactured and go away for small
change since the DCC tapes are no longer available.
The tape decks themselves, however, are of good quality
and for backward compatibilty they can play analog tapes
as well. Plus, they have a digital out!
So with any soundcard that has a digital input you can
easily transfer your old analog tapes to digital audio
of whatever format you prefer. No hassling with hum or
the proper recording level. Very easy. I picked up a
Philips DCC 450 (compact version) for about $25.
All the best,
Dieter Michel
Peter,
> The sound ... O;-) <
Of course, that explains nothing.
I am not saying an SB Live is equal to the best sound card ever made. But
it's not nearly as bad as a lot of people seem to think. In fact, it beats
even the best cassette recorder in any way you care to measure. :-> )
Also, the OP is using speakers that cost $99 including two satellites and a
powered sub, no doubt in an untreated room. And you're fretting over the
difference between 0.01% and 0.001% distortion?
--Ethan
Ross,
> You haven't measured any of these values for either piece of equipment. <
I've measured - or seen specs for - tons of audio gear over the years. I
have a very good handle on what the specs mean, how they translate audibly,
and at what amounts they become objectionable.
> Resampling error is quite specific. <
But "resampling error" is not a spec! It's an opinion. Either you can quote
which *already established audio spec* is affected, and by how much, or you
cannot.
> It's the reason why the original poster think his MP3's sound so bad,
worse than his tape deck. <
How can you claim to know what the OP heard, or his level of understanding
on audio matters? I think Mike nailed it when he said, "He's just ...
lacking the confidence in his own judgement." This is a huge problem in
these groups. Every day I see newbies post that they're not happy with their
home-made recordings, and ask us what tube compressor or outboard word clock
they should buy to make their lame efforts sound like a commercial CD. They
think the problem is missing some key piece of gear, all the while
overlooking that their gear is fine and it's their skill that's lacking.
> You haven't posted any facts. <
I did! I explained that "Even the best cassette deck is inferior to an SB
Live card in any way you care to measure," then listed the four audio specs:
Dynamic Range, Distortion, Frequency Response, and Wow & Flutter. So in
which of these specs is a Nakamichi cassette recorder better than an SB Live
card? Or have you discovered a new audio parameter that nobody else yet
knows about?
I repeat again that my point is not to argue or flame, but rather to keep
things focused on what really matters and what is known by science.
--Ethan
Archived from groups: rec.audio.pro (More info?)
In article <aKKdnZWHgc2Te-nfRVn-vw@giganews.com> "Ethan Winer" <ethanw at ethanwiner dot com> writes:
I didn't say anything about that, but I indeed noticed it. It's no
particular credit to his speakers that he can tell the difference
between an MP3 (of unspecified data rate, sample rate, and encoder)
and direct playback from a decent cassette deck. "Dull" was the only
real descriptive word he used, and that's more likely a function of
sample rate and encoding than the A/D converters and internal sample
rate conversion of the SoundBlaster.
So, we're still just pissing in the wind. But if it would make him
feel better to get another sound card, it might as well be an M-Audio
Audiophile or Echo Mia. At least they're generally little or no
trouble to install and don't have the SoundBlaster's inherent
resampling that seems to scare people around here.
I've never been so unlucky as to have a SoundBlaster except for an
early one which I never used for anything but computer audio, so I
really don't know just how bad a modern one can be at its worst, but I
still support your contention that it's as good as the cassette. I'll
bet that if the original poster made a PCM recording at the proper
record level, he'd find that it sounded essentially the same as the
cassette source. If it didn't, it would be time to troubleshoot
settings to be sure he wasn't recording at an 11 kHz 8-bit default or
something like that.
Irrelevent.
Just because you don't know what resampling error is doesn't make it
an opinion.
>I did!
No, you haven't posted any facts.
That's just your opinion. An opinion which you have no measurements
nor any obsevervations to substatiate.
>... then listed the four audio specs: Dynamic Range, Distortion,
>Frequency Response, and Wow & Flutter. So in which of these specs is
>a Nakamichi cassette recorder better than an SB Live card?
In which of these "specs" can you provide any evidence, any facts
whatsoever, that an SoundBlaster Live! is better than the orignal poster's
Your speculation is not science.
Ross Ridge
db //
I would have thought that 'better' was self-evident, given the purpose for
which I was putting the card.
Better meaning lower distortion figures?
Better meaning flatter frequency response?
Better meaning fewer digitisation artifacts?
Better meaning NOT resampling to a different frequency?
Or maybe NOT better, meaning that any of the cards I mentioned will
do all of these things comparably, within human audibility.
Put it this way: For straiht two-channel recording to digital
(16bit/44.1kHz), minimal processing if any, and burning to CD-R, will any
of the cards cause audible artifacts? If so, will any of them NOT produce
audible artifacts? If so, which problems are the lowest level, based on
listening criteria?
Colin
> quote
> you
> cannot.
There is indeed an "error", or at least a "change" caused by resampling
between 44.1 and 48. If it is audible and if so to what extent is it
significant is an entirely different question.
I just took a short 44.1 audio file and made an inverted copy. When I sum
the 2 together, there is absolutely no resulting sound because they are bit
accurate, only inverted. If I sum my original to one that has been
converted to 48 and then inverted, there is a significant resulting signal,
which proves something is most definitely changed. A Sound Blaster card
that resamples everything to 48 definitely changes the sound compared to a
bit accurate card that comes in at 44.1 and stays there. You cannot state
this is an opinion. It is a fact. How significant it is, is indeed an
opinion until someone devises a test to evaluate.
Julian
But then you are dependent on the cassette tape quality of the $25 recorder
which probably isn't as good as the nakamichi in question.
Julian
On Sun, 1 May 2005 23:25:20 -0700, "Julian Adamaitis"
>> quote
>> you
>> cannot.
Excellent test idea! The point Ethan was making is that resampling
error (or anything else) is more meaningful when expressed with
some sort of numerical value. The mere fact of resampling does
not in itself cause distortion, it has to do with the algorithm used.
(Specifically, the filter used.) Typically the resulting distortion
is inharmonic, so it sounds worse than an equivalent percentage
of harmonic distortion. (I don't have a handy way to quantify how
much worse, since it has to do with psychoacoustics.)
But your test should at least give an accurate numerical value,
since the difference signal is a measure of the distortion.
To make readings really comparable, everyone would need to agree
on a standard input signal and a method to average the
resulting difference signal. But even without a standard, we
might come up with some simple description, such as "difference
peaks up to X% of original signal peaks on solo brass instruments"
or whatever. I like it!
Best regards,
Bob Masta
D A Q A R T A
www.daqarta.com
In article <42757b88@news.nucleus.com> cbigam@somewhereelse.nucleus.com writes:
As I understand it (I hope I'm taking about the right thread here),
you're making MP3 versions of a cassette tape. In my book, "better" is
irrelevant because you'll never hear better. The cassette and the MP3
conversion are "worse" than all but the worst sound cards.
I believe that all of those will be overshadowed by what you're doing
otherwise. The only one that I can't attest to is the resampling
issues which so many people seem to be bothered by. I really don't
know how bad this is, but I do know that it's very easy to tell the
difference between even a mediocre sound card's direct PCM recording
and a 128 kbps MP3 with most of the music that I choose to devistate
with MP3 conversion.
That's pretty much what I've been saying. I'm sure that when comparing
PCM recordings of good sources, many humans will be able to rank some
cards as being "better" than the others, but since you have a source
of questionable quality (you probably don't have anything above 10
kHz, and with less than 1% THD, so why worry about tenths of a dB of
non-flatness or a few hundreths of a percent distortion?) and you're
further buggering your recording with data reduction, the quality of
the sound card is pretty much a wash.
> listening criteria?
Everything produces artifacts. I believe that FOR YOUR PURPOSES the
differences, while perhaps distinguishable, will be insignificant. If
you were talking about forensic or archival (that is, putting it away
for history, not just listening to it next month) work, then I would
recommend nothing but top shelf products.
Take this as you wish. You can pay more money and get better accuracy.
It's your decision, though, as to where to make that trade-off. If
spending $100 on a new card will make you feel better about the whole
thing, then by all means do so. But I wouldn't advice you to spend
$1000 for what probably won't make a tenfold improvement in sound
quality of your final product.
"Bob Masta" <NoSpam@daqarta.com> wrote in message
news:42761e84.1436493@news.itd.umich.edu...
>>> quote
>>> you
>>> cannot.
>>bit
>>signal,
OK, I can easily tell you that. The original sound source has been
normalized and peaks to 0dB. the mix of the original and the out of phase
44.1 - 48 converted version peaks to -7dB. Not much cancellation! This was
with a mix of acoustic instruments - guitar, piano, violin and bass. The
low frequencies cancel well. It is the treble and upper midrange which is
left over to give the difference signal. I tried doing the same thing with
sine waves and the result is much much less dramatic. Instead of 7 dB of
difference on peaks, there is about 66 dB, so the original and the converted
are very close to identical with sine waves. I tried 20, 400 and 10,000 Hz
sine waves, all about 66 dB. That's a huge difference between the real
music and the test tones. Anyone care to speculate why?
Julian
Actually, I jumped in on this thread. I might do _some_ cassette copies,
but my main goal is digitising my irreplaceable vinyl. My analog end is
fairly good (Rega table going through an ancient Rotel preamp), and I have
no intent of going to mp3. I'm burning all of this stuff uncompressed to
CDR, and if I wanted a more portable format I would either use FLAC or
OGG over MP3.
(bits snipped)
>> listening criteria?
Everything produces artifacts. The question is whether those artifacts
are audible. If I took the extreme case of a DAT deck plugged (via analog)
into my sound card, would I be able to hear the difference between (say)
the Audigy 2ZS and the Revolution 7.1, and the Audiophile 2496? Would the
end product (wav file burned to CD) sound different than the original DAT
tape?
Colin
In article <42761e84.1436493@news.itd.umich.edu> NoSpam@daqarta.com writes:
A reasonable numeric expression could be the percentage of listeners
tested who can identify when program material has been "resampled"
with an accuracy better than chance. A number based on measurement of
a single frequency test signal, while real, is going to be pretty
meaningless when it comes to the elusive "audio quality."
You could come up with a number by using pink or white noise as a test
signal, inverting a resampled version, summing with the original, and
expressing the RMS amplitude of the "leftovers" as a percentage of the
RMS amplitude of the original signal. But that wouldn't tell you how
it sounds. Only humans can do that.
Julian,
> That's a huge difference between the real music and the test tones.
Anyone care to speculate why? <
Did you match the levels to get the deepest null possible? If you just
convert and mix, and a tiny but otherwise unrelated level change is
introduced in the process, that -66 dB can easily rise a lot. It takes *very
little* change in level of one source to reduce the effect of a nearly
complete cancellation. Far more than the 53 dB difference implies.
--Ethan
Ross,
Which specs? Okay, for starters, the signal to noise ratio is about 20 dB
better on an SB Live card. And THD and IM distortion are much better too,
but several orders of magnitude. Frequency response is also much better on
an SB Live card. And wow and flutter are infinitely better on the SB Live
because a sound card has no wow or flutter. Finally, an SB Live has no
modulation noise either, and modulation noise is particularly bad (-40 dB or
higher) on all cassette recorders.
Now, if you have any hard facts with which to refute this, I'd love to hear
it.
--Ethan
> tape?
I don't know. I do know I preceived a fuzzy smeared quality to things
recorded through my SB Live! that went away when I got my LynxOne.
Julian
> *very
I converted using "convert sample type" in Audition. Then I inverted. No
volume changes were introduced.
If I take a file and simply convert before mixing, there is zero signal,
nada, zip. Not even a flicker of the meters at - 120dB. I can thereby
show my method accurately predicts if 2 files are identical. If I messed
with volumes after doing my sample rate conversion, I would have no
reference anymore or proof of my technique's accuracy.
I suspect there will be no benefit by nulling levels. I suspect changing of
levels will only increase the difference signal.
I'm just wondering why there is so much more difference signal using music
than test tones. One clue is the volume of difference signal is not
constant using music. it peaks quite heavily on the attack of each
percussive guitar strum with the music I used. the meter readings vary
roughly between - 36 and -24, but on the guitar hits it peaks quite heavily
up to as much as -6dB which is quite significant. the difference signal is
only 6 dB quieter than the original which peaks at 0 at these points. You
got to be able to hear that, don't you think, Mike? It is apparently the
attack part of the envelope that is most effected by resampling. When
looking at the difference signal generated by using sine wave test tones, it
only varies about +/- 1 dB and it doesn't appear the difference is effected
by frequency of the tones. I used 20 Hz, 400 Hz, and 10 kHz and the
difference signal was about the same magnitude in each case.
Julian
Mike,
> But if it would make him feel better to get another sound card, it might
as well be an M-Audio Audiophile or Echo Mia. <
Agreed. I have a Delta 66, and several of my friends have an Audiophile
2496, and they're both great cards.
> I really don't know just how bad a modern one can be at its worst <
Not bad at all. Certainly nothing like some people seem to think. And
certainly far better than any stupid cassette recorder! :-> )
--Ethan
There are 1535 identified and unidentified users. To see the list of identified users, Click here.
By mubin, 1 day ago:
Do you mean when jack is connected then there is that noise? Then it is the cable. In my...
gamerk316 - bronze Expert
Specialties : Audio Tech, CPUs, Graphics, Win 7
7505 messages since 1970/01/01
