Though I've been burning CD-Rs for a few years now, I've just learned
all about read and write offsets. Does the write offset affect the
sound quality of audio in any way? On one hand I would think it would
only affect the starting points of tracks, etc. and the music wouldn't
really be affected.
The reason I bring this up is that I've been having inconsistent
results burning an album that is on my hard drive. Listening to the
WAV files, everything sounds great. But I've tried burning at
different speeds (I have a Sony CRX140E capable of 1x, 2x, 4x and 8x)
and with different brands and formulations, and the results end up
either sounding fuller and flatter (as if there's more low-end
frequencies) or sounding faster in tempo (probably jitter) and higher
in pitch, to the point where there's incidents of siblance or "essing"
that don't appear on the slower-burned copies.
Anyways, all this has led me to wonder if a write offset changes the
phase of the music, or if the timing subcode is wrong and thus sounds
different, etc.
If anyone has any insight, I'd appreciate it. Thanks!
the reason for the offsets is to make up for the fact that not all CD
players start/stop at the samepoint
wouldn't
> really be affected.
That is correct.
"essing"
> different, etc.
> - Greg Yim
> ibgby@msn.com
Those are evidence of high error rates. As has been stated here in the
past, your choice of media/ burning rate will have an effect on the
sound of the final product.
What works best depends upon your burner / media combination. I have
found that I get the best results by using a burn rate that is no
greater than 50% of the max burn rate of the burner. In your case,
that might be 4x, but 2x may be even better.
wouldn't
> really be affected.
That is correct.
"essing"
> different, etc.
> - Greg Yim
> ibgby@msn.com
wouldn't
> really be affected.
That is correct.
"essing"
> different, etc.
> - Greg Yim
> ibgby@msn.com
<ibgby@msn.com> wrote in message
news:1114922250.243902.315780@o13g2000cwo.googlegroups.com...
Could be that your head is not in the identical position for each replay.
Could bedifferent error rates on the different media/speeds, or could be
imagination. Don't think it would be anything to do with an offset.
