I have an old signal generator in which i am measuring the output voltage
to get a basic mic level [ my math is not so good , but .7 v is considered
+ 4 Line level ? ] for checking out a preamp i built .
"GKB" wrote ...
> voltage
> considered
> tia for any help , regards Greg
Professional Line Level equals 1.228v. +4dBu=1.228v.
In article <PT8de.1186302$6l.202027@pd7tw2no> gboboski@shaw.ca writes:
0 dBu is 0.775V. +4 dBu "nominal line level" in round numbers is about
1.2V. A good healthy mic levl is around -35 dBu which equates to
0.014V (14 millivolts).
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
0.775V is 0dBu
1.23V is +4dBu ( 0VU ) commonly taken as the 'line level' reference.
-35dBU might be a good o/p from a capacitor mic. What if it's not that
genre?
A good dynamic mic reference level for speaking voice is -54dBU or about
1.5mV rms. Add 8dB above that for peak (to -46dBU).
Some dynamics give a lower ref level (about 0.9mV).
A ribbon mic produces even less voltage and usually that needs to be
increased with the use of a step-up transformer by about 7-10dB to nurture
lower-gain preamps.
Line-up (ref) line level in UK is 0dBU or 0.7746mV, at 400 Hz, 800 Hz, or
1kHz.
Peak is strictly 8dB on top of that.
"Mike Rivers" <mrivers@d-and-d.com> wrote in message
news:znr1114971924k@trad...
>> voltage
>> considered
"GKB"
> considered
** There is no such thing as "mic level" - any fool here who says there is
is an ass.
Depending on the actual mic and its usage the output level varies from
almost nothing to several volts.
Why do you think mic pres have an input gain control with 50 - 60 dB range
Thanks for all the replies , Mr Rivers was the closest to what
i was looking for [ thanks Mike ] , and if that wasn't clear , it was "
what would
an " average " mic put out voltage wise so i can set the signal generator
in the ballpark !
something in the middle not a ribbon , not a modern condenser being yelled
into ,
perhaps a voltage down 50db from 0 , Not critical just a place to start
from .
spread the love , regards Greg
voltage
considered
In article <3dmg24F6t603tU1@individual.net> philallison@tpg.com.au writes:
There's no specific number for calibration, but there's a voltage
range that's usually considered "mic level" and a range that's
considered "line level." There are mics that put out line levels, and
there are lines that put out mic levels.
So that they can accommodate what comes out of most microphones most
of the time. But you won't find too many mic preamps that will take a
"line level" signal (say in the range of -20dBu to +24 dBu) at the
same input connector as a mic without at least switching in an
attenuator.
In article <COnde.15725$Y46.2684@newsfe1-win.ntli.net> jim.greg@ntlworld.com writes:
> genre?
Because of all the idiots hooking mics to recorders today and saying
things like "my mic isn't hot enough" or "my mic is too hot" without
considering things like gain structure, manufacturers are making mics
with pretty much similar sensitivity. It's no longer univerally true
that condenser mics have a higher output level for a given SPL than
dynamics.
It's very true, however, that speaking a foot or so from a microphone
will give an eyeball average output level around 20 dB lower than
someone singing into a mic at a few inches. This is why a microphone
preamp needs to have good performance over a wide dynamic range.
The original poster was looking for a test signal to run through a mic
preamp, and something in tne order of -35 dBu is a good middle-of-the
scale level - not high enough to overload, not so low that noise
becomes a problem.
EricK wrote:
>> voltage
>> considered
0=.775
Ok - I think you got the numbers regarding the accepted reference levels.
When designing a mic amp you should consider the situations in which it is
likely to be used.
Quiet singing from a distance from the mic may require as much as 80dB gain.
Rock 'n roll usage with close miking may result in overload of your mic pre (
assuming typical circuitry ) if you can't wind the gain down to around 20dB (
or less even ! ).
To perpetuate the story , it's an old tube model signal generator with
numbers for markings, as i've never had much for test gear [ check , check
and not even for design , more to trouble shoot .
thanks again ALL
regards Greg
"Pooh Bear" <rabbitsfriendsandrelations@hotmail.com> wrote in message
news:4276EB42.118A041C@hotmail.com...
voltage
considered
> likely to be used.
gain.
pre (
20dB (
> or less even ! ).
> Graham
