Tom's Hardware > Forum > Audio > Pro Audio > Did I kill my power amp?
Forum Audio : Pro Audio - Did I kill my power amp?
Archived from groups: rec.audio.pro (More info?)
My Adcom 535 II seems to be dead, and I'm afraid I *may* have been at
fault. I say "may" because I bought it off eBay and never got the chance
to properly test it (yeah I know, spare me the lecture).
I was trying to get it to work with my newly finished LS3/5A monitors
and external crossover. Unfortunately I had the crossover incorrectly
wired at first so the HF drivers were NOT in the circuit. Everything
else was wired correctly (ie. the inputs and LF outs) so the amp was
powering the LF drivers only.
At first it did pretty much nothing and would only make crackling sounds
in the speakers when I turned the preamp way up, to the point of
distortion....I could get the "clip" light to light up on the 535, but
all the speakers did was crackle relatively quietly.
Now it won't make any sound at all (even crackling) and I can't get the
clip light to come on even by heavily overdriving the preamp.
Would it be possible that the impedence load due to the lack of a HF
driver killed the amp? Also, I'm using my mixing console (Mackie
1604vlz) as the preamp, could that be the problem?
I think it's more likely that I got ripped off...what do you think?
Anyway, I'm pretty sure it's dead. Does it sound like it's an easy fix
(ie. worth fixing) or should I find something else? Thanks!
Jonny Durango
Sponsored Links
That's pretty much a vanishingly small possibility.
LOL ! Not in the sense that that it makes crackles but you might get the
piss taken for owning one !
Yes - sounds like it.
Depends on you I guess. What bothers me more is that you'd use an unproven
amp to power some new presumably home made monitors.
Graham
Reply to Anonymous
where was the fuse??
dale
Reply to Anonymous
Where the sun shines not, along with the OP's head! ;-)
Reply to Anonymous
I think if you run one of these amps into clipping, you will damage it.
These are not PA amplifiers.
Check the fuses. Odds are you've blown at least one.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply to Anonymous
In article <LqadnTdhebHHv-bfRVn-sQ@comcast.com> jonnydurango1BUSH_FROM_OFFICE@comcast.net writes:
You bought a broken amplifier.
Lecture spared.
Of course you did. (still trying to spare the lecture)
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
> it. These are not PA amplifiers.
I have no idea what this amp is. However, for any commercial amp to blow
itself up just because it goes into clipping would be an amazingly poor
design. Like, maybe oscillating at RF.
I just don't see it happening.
Kevin Aylward
informationEXTRACT@anasoft.co.uk
http://www.anasoft.co.uk
SuperSpice, a very affordable Mixed-Mode
Windows Simulator with Schematic Capture,
Waveform Display, FFT's and Filter Design.
Reply to Anonymous
- 0 +
chance
sounds
but
the
fix
> Jonny Durango
Are you sure you had the amp connected correctly? In most amps that I
have worked with functioning clip indidicators suggest the OP stage is
OK unless they are hard on all the time with no signal input. It seems
to me you were driving it into a short. If you are lucky you just have
blown fuses. You need to give it to a tech to look at.
Steve Lane
Reply to steve
On Fri, 06 May 2005 00:53:29 -0700, Jonny Durango
Is this a two-pole (12dB per octave slope) or three-pole (18dB per
octave) crossover? For these the HF filter will generally be a
capacitor and inductor in series, with the HF driver across the
inductor. It's a series resonant circuit, but the HF driver damps the
resonance. If the driver isn't connected, there can be a seriously low
impedance (1 or 2 ohms) at or near the crossover frequency, and any
signal going through the amp with frequency components in that range
will cause a large current to flow. I won't say for sure this is what
happened, but it's a possibility.
See above. It's not that it's a higher impedance as you might
expect, but a lower impedance at one frequency band.
That should be fine.
It's hard to say now...
>Jonny Durango
http://mindspring.com/~benbradley
Reply to Anonymous
> My Adcom 535 II seems to be dead......
> .......I was trying to get it to work with my newly finished LS3/5A
monitors
> wired at first so the HF drivers were NOT in the circuit......
> .....I could get the "clip" light to light up on the 535, but
> all the speakers did was crackle relatively quietly.....
> .....Now it won't make any sound at all (even crackling) and I can't get
the
> clip light to come on even by heavily overdriving the preamp.....
> ......I think it's more likely that I got ripped off...what do you think?
I bought an Adcom 535 MkII off ebay. It was dead the first time I
turned it on. I replaced the fuse outside the case. I peered at the two
fuses inside the case. I took it to a tech. After six weeks the amp
was ready. I asked the tech what was wrong with the amp. He
shrugged his shoulders. He said he cleaned it up and resoldered joints.
The amp runs hot (no cooling fan) and stresses the solder joints, he
said. Cost $40. I thought wow, he only spent an hour on it.
A few weeks later the amp was dead agian. This time I took the
case off the amp. There were dust bunnies and cat hair, etc. I
thought, hey, I thought the tech cleaned in here! I replaced the
outer fuse. The amp worked again. I figured I had blown the fuse by
turning the amp on and off using the power strip. I had heard a surge
of energy coming through the speakers. Now I make sure the amp
itself is turned off whenever I turn the power strip on and off.
My theory is that the tech never opened the amp case. He changed the
outer fuse and charged me $40. I'd have been fine with: "I changed the
fuse, it'a forty bucks".
Tim Sprout
Reply to Anonymous
"Jonny Durango" <jonnydurango1BUSH_FROM_OFFICE@comcast.net> wrote in message
news:LqadnTdhebHHv-bfRVn-sQ@comcast.com...
First rule: Don't test a new amplifier into the good speakers. Use a pair of
stinkers you got at a yard sale. If the amp is bad, you won't kill your
expensive speakers.
Highly unlikely. Some tube amps will blow up if they're operated into an
open circuit, but I haven't seen a solid-state amp that'll do that. Besides,
it wasn't an open circuit. It had the woofers hanging on it. No.
Extremely unlikely.
Yep. You bought a busted amp.
Before you do that, go over to your speakers and palpate the woofers: spread
your fingers out evenly over the cone, and gently press. Does the cone move
freely? If it is frozen, or feels rough, like it's scraping, you now know
that the power amp had DC on the outputs, and has fried your woofers. And
now you have an illustration of why I recommended a Dynaco Stereo 70 for
driving LS3/5a's. A Stereo 70 is extremely unlikely to have DC on the
output.
In any case, your amp is deceased. Take it to a shop and ask for a diagnosis
and estimate. Probably your output transistors are cooked at the very least,
probably more than that.
Peace,
Paul
Reply to Anonymous
Johnny, odds are that it simply needs the supply rail fuses replaced. These are on the circuit
board for each amp channel. These amps are pretty damn hard to blow up.
Tim, the 535 & 535II are not supposed to run hot at all, unless driving it hard for a while.
At idle, shouldn't be more than a bit warm. I've had a 535II running in my system for the last
few days straight, with a tube preamp sitting right on top, and the amp is nowhere near hot.
Your amp has either mis-adjusted bias current, or has a strange problem.
Stephen Sank, Owner & Ribbon Mic Restorer
Talking Dog Transducer Company
http://stephensank.com
5517 Carmelita Drive N.E.
Albuquerque, New Mexico [87111]
505-332-0336
Auth. Nakamichi & McIntosh servicer
Payments preferred through Paypal.com
"Tim Sprout" <tman@ptialaska.net> wrote in message news:117na21tiaf9o9e@corp.supernews.com...
> monitors
> the
> Tim Sprout
Reply to Anonymous
- 0 +
Sounds like a broken amplifier to me. I would consider an Adcom worth
repairing, so take it to your local hifi repair shop and see what it will
take to bring it to life.
> I was trying to get it to work with my newly finished LS3/5A monitors and
> external crossover. Unfortunately I had the crossover incorrectly wired at
> first so the HF drivers were NOT in the circuit. Everything else was wired
> correctly (ie. the inputs and LF outs) so the amp was powering the LF
> drivers only.
> distortion....I could get the "clip" light to light up on the 535, but all
> driver killed the amp? Also, I'm using my mixing console (Mackie 1604vlz)
> Jonny Durango
Reply to Adam
There are 614 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
