Hi
I've been having an annoying problem recently, which seems have to have got worse since I installed a Radeon 9700 Pro video card.
If my machine is doing anything graphically intensive (games, video editing etc), after 20-30 mins it shuts off as if the plug has been pulled out of the socket. The only way I can restart is by taking the plug out of the wall and putting it back in. Pressing the power switch has no effect until I do this.
I tried cleaning all the fans inside the case to make sure it's not a overheating problem. My temps don't seem to be too bad (Case: 30°, CPU 52° at load).
I have a Q-Tec 400w Dual Fan power supply, and I'm beginning to wonder if this is the cause of the problem (not enough juice?).
I understand the 9700 Pro is quite a power-hungry card and maybe this is proving too much for PSU? The same thing used to happen occasionally with a GF3 Ti 200 installed, but not half as often.
My current system specs are:
Athlon XP 2000+
Epox 8K5A2+ mobo
512Mb PC2700 memory
Radeon 9700 Pro graphics
Soundblaster Live 1024
Seagate Barracuda IV 80Gb
Lite-on CD-RW (48x12x48x)
Appreciate any advice
Baz
<P ID="edit"><FONT SIZE=-1><EM>Edited by BoBo67 on 06/03/03 09:57 AM.</EM></FONT></P>
Athlon XP 2000+
Epox 8K5A2+ mobo
512Mb PC2700 memory
Baz
