Hello,
I had to do a fresh reinstall of my OS recently and ever since I did I have not been able to connect to the internet to get my others drivers running. In my device manager their is a Yellow triangle next to the Ethernet controller.
I have downloaded and tests both the modem drivers as well as the LAN ASRock drivers directly from this site http://www.asrock.com/mb/download.asp?Model=P67%20Extreme4&o=Win764 the ASRock drivers had a notification that you do not meed the required specifications or similar and neither of them solved the issue.
Maybe I have overlooked something and some one hear can help, any one attempting to help would be great help and I want to avoid of getting a stand alone Ethernet card if I can.
