Help needed with MN-500 & CWP-854 WIRELESS-G PCI ADAPTER.
Last response: in Networking
June 2, 2004 12:23:51 PM
Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
Hello All,
I purchased a CWP-854 WIRELESS-G PCI
ADAPTER for use with my MN-500 Microsoft base
station.
My computer is running WinXP sp1.
I installed the software/driver from the CD that came
with the CWP-854 WIRELESS-G PCI ADAPTER.
The CWP-854 WIRELESS-G PCI ADAPTER utility says it is
connected but it is only transmitting and not
receiving.
The MN-500 will not assign the CWP-854 WIRELESS-G PCI
ADAPTER an IP address in DCHP mode.
If I use a static IP address for the CWP-854
WIRELESS-G PCI ADAPTER the MN-500 base station still
will not allow it into the network.
The CWP-854 WIRELESS-G PCI ADAPTER's link status is
100%, and signal strength varies if I move it further
from or closer to the MN-500 base station. Even with
100% signal strength the CWP-854 WIRELESS-G PCI
ADAPTER is not allowed onto the network.
I have also tried using the Microsoft Broadband
Network Utility and when I open it is shows 11Mbps
then immediately goes to 'No Connection' & 'No
Signal'.
Thinking this is a security miscommunication I tried
the various security options or no securtiy in setting
up the MN-500. I tried a firmware update to the MN-500
but that made no difference to the problem.
I am not using a WEP keycode. I have tried using 64bit
WEP, 128bit WEP, and no WEP. I have turned power off
the MN-500, reset the MN-500, and still the CWP-854
WIRELESS-G PCI ADAPTER shows connection to the network
but cannot access the Internet or the other 2
computers on the network.
My MN-500 is connected to a Westell 2200 xdsl modem,
with a computer wired to the MN-500, and another
computer using an MN-730 wireless pci adapter.
Is the CWP-854 WIRELESS-G PCI ADAPTER incompatible
with the MN-500 or WinXP sp1, both, or is there some
solution to this problem?
Your help in resolving this issue is greatly
appreciated.
Have a good day,
Jack
June 2, 2004 1:31:04 PM
jack,
Sorry. This is a stupid question, but since you did not
mention it in your detailing I have to ask.
The CWP-854 adapter is 802.11g, while the MN-500 is an
802.11b compliant device. Did you set-up your adapter
for 802.11b compliancy or leave it as 802.11g?
>-----Original Message-----
>Hello All,
>station.
>receiving.
>Signal'.
>appreciated.
>Have a good day,
>Jack
June 3, 2004 1:01:31 PM
Hi,
No stupid questions here if it means getting the help I
need.
I tried both the 802.11b & 802.11b/g options the nic
utility provides.
-jack.
>jack,
>>Hello All,
>>station.
>>receiving.
>>Signal'.
>>appreciated.
>>Have a good day,
>>Jack
Anonymous
a b F Wireless
June 3, 2004 2:57:33 PM
jack,
Keep it configured for 802.11b protocol since that is all
the MN-500 can handle. Since you have the MN-500, you must
have the Microsoft CD setup wizard that came with it.
Use that CD to install/establish contact with the
adapter. It will prompt you on the first page "Install
new product...". Go ahead and let it install the CWP-
854. Since you already have the drivers installed for the
CWP-854, there should be a problem.
>Hi,
>need.
>utility provides.
>-jack.
>>jack,
>>>Hello All,
>>>station.
>>>receiving.
>>>Signal'.
>>>appreciated.
>>>Have a good day,
>>>Jack
June 6, 2004 8:31:54 PM
Hi,
Thanks for trying to help. Tried your suggestion and the
adapter is still incommunicato with the base station.
Honestly, I think the adapter is pinging its heart out,
but the microsoft products just don't want to play nice.
I'm getting a refund on the adapter & will go with another
microsoft wireless or maybe a powerline adapter.
-jack.
>jack,
must
the
>>Hi,
>>need.
>>utility provides.
>>-jack.
>>>jack,
not
>>>>Hello All,
>>>>station.
>>>>receiving.
>>>>Signal'.
>>>>appreciated.
>>>>Have a good day,
>>>>Jack
