Ok, here's the deal. I run the SATA RAID Configuration Utility and create a RAID Volume with my two WD 36GB Raptors (note: these are completely new drives). Then when I load again, I receive an error saying that there are no detected FAT32 partitions.
So I partition the drives, while they are still in the RAID Strip. The problem, though, is that afterwards, I can't load the C drive and FDISK says my hard drive has only 5 Gb of memory.
So I delete the partition and remove the RAID Array. I then run FDISK again and this time it correctly reads the drive size as 36 Gb, but this is only for one HD.
So my question is, how do I get both drives partitioned and into a Raid 0 Array?
(I don't really know what I'm doing)
System Specs:
P4 2.8Ghz 800Mhz FSB
P4P800-Deluxe Mobo
2x 36Gb WD Raptor
2x 512Mb Corsair XMS PC3200 RAM
<P ID="edit"><FONT SIZE=-1><EM>Edited by NoUse on 06/07/03 02:40 PM.</EM></FONT></P>
System Specs:
P4P800-Deluxe Mobo
2x 36Gb WD Raptor
