Tom's Hardware > Forum > CPU & Components > Other Components > Power supply recommendation
Forum CPU & Components : Other Components - Power supply recommendation
I'm looking for a good decently priced (less than $60) power supply 400+ watts. Any suggestions.
Sponsored Links
How about a Fortron or Sparkle PSU?
My CPU fan spins so fast that it creates a wormhole :eek:
Reply to svol
Fortron's "350W" power supply outputs 400W, the good model is $32 at Newegg.
Fortron's "400W" power supply outputs over 450W, it cost $60 at newegg.
Sparkle sells these same supplies for $7 more at Newegg.
<font color=blue>Watts mean squat if you don't have quality!</font color=blue>
Reply to Crashman
Too bad I can't find any resellers in Europe as I can use a good solid PSU for my next PC upgrade plans. :frown:
Reply to svol
I see some sellers in Great Brittain! What would the shipping on that be?
These supplies go under various names, FPS, Fortron/Source, Power Man; Sparkle Power and Aopen use them as well, so you SHOULD be able to find one.
And you DO know someone who ships internationally from the States :smile:
Reply to Crashman
Interesting I'm going to look some more... and shipping from the UK to The Netherlands wont be very much.
And indeed otherwise I know who to contact.
Reply to svol
There are 1215 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
