Tom's Hardware > Forum > CPU & Components > Other Components > Upside down Power Supply
Forum CPU & Components : Other Components - Upside down Power Supply
Has anyone had this problem:
- Antec TruePower 380 power supply
- AMS gTOWER case
- the power supply is <i>upside down</i>, in other words, the internal fan points towards the top of the case rather than towards the mother board. Arggg!
Antec confirms the orientation problem, still waiting to hear from AMS to see whether they make a different power supply mounting plate.
Any suggestions or comments would be much appreciated.
cheers, Brendan
Sponsored Links
you should be able to mount it with only 2 screws. then if you really wanted to you could drill some holes for the other holes.
<font color=red> black </font color=red> <font color=green> white </font color=green> <font color=blue> yellow </font color=blue> <font color=orange> purple </font color=orange> <font color=black> red </font color=black> <font color=yellow> green </font color=yellow> <font color=purple> blue </font color=purple>
Reply to jihiggs
my opinion - graba pencil, remember X marks the spot, find a drill and have fun
<b>I have nothing better to say</b>
Reply to error_911
Grr, I hate that, I'm using such a case right now!
<font color=blue>Watts mean squat if you don't have quality!</font color=blue>
Reply to Crashman
Yea, if it were only so simple ... the inner perimeter of the p.s. mounting plate is shaped like a keyhole. The p.s. won't fit in rotated 180 degrees without "dremeling" (is that a word?) the inner hole to accomodate the fan where the power switch and power cord are right now. Oh well. I always wanted a "MultiPro Rotary Tool ..." Unless there's an easier way to shape aluminum?
Reply to bcreane
you can always cut it with some metal scisors, or just use some sandpaper (or a metal file) and just sit there with it for a lil while till you can shape out what you need... ideally, dremel + metal file will give you a fast and clean looking fix
Reply to error_911
Wow! I called AMS tech support ... this is fixed in the newer versions of this case. In addition, they make a retro-fit plate that they're shipping for free, immediately. Right on AMS!
Reply to bcreane
I was about to give an option, but crap, that deal with AMS sounds pretty awesome
Right on indeed
It's all good ^_^
Reply to namek0
ams huh? sounds like they have pretty good service, ill have to check them out.
Reply to jihiggs
There are 966 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
