Tom's Hardware > Forum > Smartphones & PDAs > Palmpilot > how to replace Visor Pro battery?
Forum Smartphones & PDAs : Palmpilot - how to replace Visor Pro battery?
Archived from groups: comp.sys.palmtops.pilot (More info?)
Hi, all. I have a HAndspring Visor Pro and the battery is holding less
and less of a charge as time goes by. I think it is about to go dead. Is
there a simple, relatively inexpensive way I can replace it? TIA.
Bob
Sponsored Links
On Thu, 8 Jul 2004 16:03:28 -0500, Robert Kim <roberth@purdue.edu>
>Bob
This I would like to know as well. Where can you get a replacement
battery? http://www.gethightech.com/ doesn't even seem to have it.
Reply to Anonymous
Archived from groups: comp.sys.palmtops.pilot,comp.sys.palmtops (More info?)
krewl, I have 2 Visor Pro's and just got done putting all my info on the
2nd one. Let me rip apart the old one and see what battery it does take.
If it is one purchasable at a store, I'll post it so you can get one, too.
In the meantime, if anyone out there has any idea on replacing the battery
in a Handspring Visor Pro, please let us know.
Bob
> >Bob
Reply to Anonymous
On Sat, 10 Jul 2004 09:35:27 -0500, Robert Kim <roberth@purdue.edu>
Sounds good!
>Bob
>> >Bob
Reply to Anonymous
> Sounds good!
krewl, I'm looking at my Visor Pro battery now. It is wrapped in black
plastic/rubber (?) and has on the side:
14-0020-00
F27A
Doing a web search now for this battery. I'm wondering if it is the same
battery as, say, the Visor Edge that's on sale at gethightech.com .
If you have any insights, please post them. TIA.
Bob
Reply to Anonymous
On Sat, 10 Jul 2004 13:36:08 -0500, Robert Kim <roberth@purdue.edu>
>> Sounds good!
>14-0020-00
> F27A
I am quite sure that it is not the same batter as the Edge. I did
check with them a few months ago and they said it is is different
battery and that they were not planning on carrying the battery for
the Visor Pro. :(
Will do! And, thanks for the battery number. That should help a lot in
tracking it down.
>Bob
Reply to Anonymous
>> Sounds good!
>14-0020-00
> F27A
>Bob
I can't figure out why Handspring and battery sources seem to have
abaondoned the Visor Pro. For example, here are the batts for all the
Handspring/Visor models, except for the Pro :( Go figure:
http://www.handspringbattery.com/?CMP=KNC-goog31
Reply to Anonymous
> >> Sounds good!
> >14-0020-00
> > F27A
> >Bob
Visually, but with no way to compare the size since only the battery is
shown but nothing else, my Visor Pro battery appears to look most like the
Edge battery. I'm going to call Handspring on Monday and see if they can
give me at least voltage/current specs for the Visor Pro battery, then
I'll order the battery closest to meeting those specs and try it out.
Since this Visor Pro is useless without a working battery, I have nothing
to lose other than the cost of the new battery if it doesn't work.
Bob
Reply to Anonymous
There are 1241 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
