S/PDIF sound card
I'm looking to build a new system. I want a sound card that has digital optical or coxal out puts, so I can plug the system into my reciever. Does any know of and recommend any such sound cards? Or maybe if some one know of a motherboard with those built on as well. Thanks for any leads.
Lead, follow, or get out of the way!<P ID="edit"><FONT SIZE=-1><EM>Edited by Jag2500 on 06/13/03 10:47 AM.</EM></FONT></P>
2 answers Last reply
More about pdif sound card
  1. The current best value motherboard, the Abit IS7, has both digital in and digital out, via digital optical connections.
    You can check out a wide array of 865/875 boards in Anandtech's latest roundup.
    <font color=blue>Watts mean squat if you don't have quality!</font color=blue>
  2. The nForce2 series with the MCP southbridge (aka: Soundstorm, or 5.1 audio) also has digital out, if you're an Athl-ete.
    umheint0's phat setup --> <A HREF="http://home.cc.umanitoba.ca/~umheint0/system.html" target="_new">http://home.cc.umanitoba.ca/~umheint0/system.html</A><--
Sound Cards Font Components
