I am having the same problem that others are having here. BSOD and the Driver Power msg. Hard to restart oe shut down. I ran Windows Debugger and the mini dump msg. was.
Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
I am sending the link to my cloud with the entire minidump file.
http://sdrv.ms/VJZV3y
Thank You
rocker444
Thank You
rocker444
