I have a Delta 1010LT with Windows Xp.
When i istalled it it was ok..was working all..after a time (2 or 3 days)
every sound is earable really in bad way.
Its like broken sound and with strange reverb.
Someone have the same trouble or have some ideas how to fix it?
Thank you all
U¿ytkownik "Sa" <sadespam@ctiri.sk> napisa³ w wiadomo¶ci
news47le.27029$795.828943@twister1.libero.it...
> Hi all,
* Did you check settings (Delta Control Panel - traybar icon : black M) ?
Maybe there is something wrong ? Close all applications that are using audio
and check :
- codec sample rate (set at least 44.1 and check - Rate Locked
- DMA buffer latency - try some high settings
- uncheck anything in : Input Channel Phase +180
- on bass managment check - General settings : OFF
- on Bass Managment/Speaker Placement set everything off
Settings are all ok..
Its really a strange thing...
I have a B2C2 card for satellite tv.
When i use that program for look tv, audio work good, i close the software
and audio works again good...no troubles
I haven't try to restart pc, but i guess on restart it will go again bad..
