Hi, Silly question, but I bought this used Sony C76 Condenser
microphone (shotgun) from someone, it came with a super old battery
that had a weird shape and two completely flat heads. Inside, it says
the microphone can take the following:
HD-7D (9.45v)
E-177 (9.8v)
TR-177 (9.8v)
Now I've asked around and was told the replacement is a Duracell
Procell PC177A 10.5v battery. I've searched in google and I must say
mine didn't look like that at all. The 177a has a female pin at one end
which wouldnt fit in my C76. I've seen the PC175a which looks more liek
mine (from teh picture) but it's only 7.5v. Which one should I use???
In article <1117177482.065893.211430@z14g2000cwz.googlegroups.com>,
>HD-7D (9.45v)
> E-177 (9.8v)
>TR-177 (9.8v)
Hmm... how about a PX-12?
The problem is that none of the old mercury batteries are still legal
in the US, and alkaline batteries with the same form factor are going to
have very different voltages. It may become a matter of stacking up
625 cells until they fit in the slot.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
In article <1117240927.755868.161800@o13g2000cwo.googlegroups.com>,
>What's a PX-12? I did a Google search, but only PC parts come up...
It's a size of alkaline battery... I think it is a stack of 625-size
cells inside a steel tube.
Go to a local battery vendor and show them what size you have and what
voltage range you want.
--scott
In article <d7bb0f$nm1$1@panix2.panix.com> kludge@panix.com writes:
If there's a Batteries Plus store or some other shop that specializes
in batteries near you (http://www.batteriesplus.com of course) take
the old battery, if you have it, in and ask them to make you a
replacement. If you don't have the old battery, bring in the
microphone so they can measure the size of the compartment, and tell
them the voltage you need.
They can assemble button cells and seal them up in a piece of shrink
tubing so it will look and feel like a battery.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
I found a battery that fits mine. It is cylinder and has ends like a 9 volt battery. I will go home tonight and look up the model. They are about $9. dcweekley@ualr.edu
