Tom's Hardware > Forum > Audio > Pro Audio > digital dc offset problem
Forum Audio : Pro Audio - digital dc offset problem
Archived from groups: rec.audio.pro (More info?)
When i use the digital output of the A/D converter AD192 of the preamp
PRESONUS
EUREKA i get a DC offset that produce a low freq noise (about 0 to 10
hz)of -40 db . Is that normal ? Is the converter broken ? when i
connect the analog output
to my audio card there is no dc offset . To be sure that the problem is
only in the a/d converter of the presonus eureka i tried the digital
output with 2 audio card , the echo layla 24 and a soundblaster live ,
and i found the same problem .
Sponsored Links
In article <1117185064.926513.181980@o13g2000cwo.googlegroups.com> lorvel@tiscali.it writes:
> PRESONUS
If it's 0-10 Hz, it's not DC offset. You just have some low frequency
noise that's below the low frequency cutoff limit of your analog sound
card.
As an experiment, you can make a "dummy mic" from an XLR plug with
pins 2 and 3 connected together. (some people prefer a 150 ohm
resistor instead of a short circuit, but for this application, a short
is probalby bettter) Plug that into the mic input and see if the noise
goes away. If it does, you're seeing noise that your mic is picking
up, just normal air movement noise. (this is why we have high-pass
filters). If the noise doesn't go away, then it's in the circuitry. As
to whether it's normal or not, that's for Presonus to decide.
How are you measuring this noise? Since you mentioned a frequency
range, I suspect that you might be applying a spectrum analyzer
plug-in to a recording. Spectrum analyzer software tools usually lie
at very low frequencies, so if that's how you're making your
measuremnts, you may be seeing something that's not really there. If
you're actually seeing a waveform in that frequency range, that's real
noise, and probalby real if you're seeing it with a mic connected.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
The problem is that i get this noise without plug in into my preamp
input any
instrument . I get this noise when i turn on my audio card ,my preamp ,
and
i select the digital s/pdf input . About the freq of this noise is
close to 0 herz , and the intencity is highter close 0 hz and lower to
about 10 or 15 hz
( there is a gradual lowering level db from 0 hz to 10 hz )
If i analyze that noise with a spectrum analyzer i find a 100% dc
offset .
I can solve this problem using the "remove dc offset" of cubase sx ,
audition
or other audio software , or using an hi-pass filter to cut the lower
freq .
I can't ear this noise 'cause the audible human freq range ,but i can't
understant the origin of this noise ,it's really strange.
I'm thinkin about the unbalanced digital output .
> > PRESONUS
> card.
Reply to Anonymous
I got the same dc offset problem when transferring tracks between
computers. Turned out the problem was in my MAudio dio2496's spdif
out... Quit using that and away the problem went. It was not an analog
issue btw since it always happened on the cards spidf out regardless of
routing.
When playing source files through it, they always had 100% dc offset.
Maybe a hosed spdif transmitter?
Reply to Anonymous
"Roger F" wrote ...
> of
> routing.
A "100% DC offset" would be full-scale DC! No sound at all.
Unlikely. More like something screwy in a driver somewhere.
Are you using the latest drivers?
Reply to Anonymous
Richard Crowley wrote:
> "Roger F" wrote ...
> > of
> > routing.
I used all their drivers.... Same result. I meant 10% btw. Finally
boxed the maudio card and installed MOTU i/o hardware, and all is well.
It is most likely hardware, since it does it regardless of drivers (or,
non-drivers in the case of the pathetic midiman stuff)
Reply to Anonymous
>> "Roger F" wrote ...
tracks between
dio2496's spdif
not an
>>> analog issue btw since it always happened on the cards
spidf out
>>> regardless of
>>> routing.
What different receivers did you have?
100% dc
>>> offset.
all.
>> Unlikely.
Agreed, unlikely. SP/DIF hardware is like most things that
are pure digital - they either work perfectly or very badly.
A 10% DC offset doesn't fit into either category, so it is
unlikely to be a hardware problem.
Finally
all is
> well.
drivers
> (or, non-drivers in the case of the pathetic midiman
stuff)
IME, MIDIMan's drivers seem to be pretty good.
Reply to Anonymous
There are 827 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
