"Vedran" <vedran.vau@gmail.com> wrote in message
news7gvs6$v4s$1@ikar.hrt.hr...
> what amplifier(s) to use?
> other boxes/splitters?
> what headphones impedance to use?
> how to connect them?
Headphone amp box. Generally run to around 6 outputs. Required headphone
specs vary from unit to unit.
Any decent amplifier that will drive speakers will handle
dozens of headphones.
Buy or build? (the connection is very simple)
Generally much higher than speakers, so you can parallel many
of them.
Frequently, a "build-out"/"attenuation" resistor is used (~100
ohms) between the amplifier and the headphones. This allows
even more headphones to be connected. It also attenuates some
of the low-level "grunge" that many power amps have. You don't
hear it through the speakers unless you have your ear up against
the speaker.
> Other manufacturers do similar units but the Behringer offers the best
> "bang for the buck"
Just be aware that on the Behringer boxes the signal degrades pretty
significantly as you move down the headphone outputs. The signal at
output #1 is okay, but the signal at output #4 is much weaker and
noisier in comparison. I've noticed this on two boxes that I've used.
YMMV.
> "bang for the buck"
YMMV.
> used.
> YMMV.
I've got a couple of Rane HC6 boxes and they don't exhibit that problem.
If the OP wants to use dedicated headphone amps, maybe they're a better
choice.
"It CAN'T be too loud... some of the red lights aren't even on yet!"
- Lorin David Schultz
in the control room
making even bad news sound good
In article <d7hrrr$lla$1@panix2.panix.com>, Scott Dorsey
<kludge@panix.com> wrote:
> In article <d7gvs6$v4s$1@ikar.hrt.hr>, Vedran <vedran.vau@gmail.com> wrote:
> Buy the Telex splitter boxes. Markertek carries them. Make sure you get
> the stereo models if you want stereo.
> Connect them to the output of any power amplifier. The Haflers are nice
> enough.
> Use whatever headphones you want.
> --scott
> "C'est un Nagra. C'est suisse, et tres, tres precis."
I've always been happy with a bunch of the Little Red Cue Boxes powered
by an amp. Redco recently dropped the price to $99.
"will" <wpmusic@sio.midco.net> wrote in message
news:1117547272.276904.58500@o13g2000cwo.googlegroups.com...
>> "bang for the buck"
> YMMV.
Is this not a multi-amp box with each amp being driven off the same signal ?
If so, then either the user has a vivid imagination, or the power supply
and/or routing in the unit is incredibly flawed.
"Lorin David Schultz" <Lorin@DAMNSPAM!v5v.ca> wrote in message news:St1ne.26078$on1.17485@clgrps13...
> > used.
> > YMMV.
> choice.
> in the control room
> (Remove spamblock to reply)
Any old power amp will drive the Furman HR-2 (dual stereo jack) stations
which can be daisy chained almost to infinity. I've noticed no signal loss
when driving up to ten of these boxes, daisychained, and loaded with 80 to
600 ohms per jack.
On 6/1/05 6:21 PM, in article 8yqne.10742$Vm4.863@trnddc01, "David Morgan
>>> used.
>>> YMMV.
>> choice.
>> in the control room
> 600 ohms per jack.
Does anybody make a version of this sort of thing that incorporates a
L-mono
R-mono
L+R mono
Switch?
"SSJVCmag" <ten@nozirev.gamnocssj.com> wrote in message
> L-mono
> R-mono
> L+R mono
> Switch?
Yes, the aforementioned Alto unit, HPA6 . Not to say that others don't too
